05-09-2006, 06:36 AM
Tuggin at the surly bonds
So, tell us more
So, tell us more. Why do you want the n600? As a driver? As a cool ecclectic car? As a restored and pristine example of Honda's early days? As an education or hobby?
05-09-2006, 08:41 AM
Re: So, tell us more
I like the n600 because:
It's unique
It's a part of Honda history
It will be way fun to drive around
education AND hobby (but then again i also have that with my sedan)
the owner of this car is notorious for not replying to emails, so I might not even hear back from him.
The biggest selling point to me is that this green car has a rebuilt engine, new suspension, etc. The cheapest engine rebuild I can find will be well over $2000, and I doubt that has a NOS crankshaft with it like this engine does.
This car is essentially just like those CRX guys who spend thousands finding every possible available option for the CRX and putting it on their car. This car has the Hawaiian head (rare), Mag wheels, optional center console, European tail lights, fog lights, etc. etc.
Assuming he replies to my query and assuming the price is right, I still might do it.
On the plus side, I think I found a rebuild cylinder head really cheap. Maybe I should slowly build my own engine for the sedan. That would be super sweet.
05-09-2006, 09:30 AM
Please forgive my ignorance. I don't doubt the engine is rare and that you are not exaggerating, I just don't understand why what appears to be a 2-cylinder air-cooled honda motorcycle engine should be that expensive to rebuild. Can a bike engine rebuild shop handle such a job if you brought it to them? Are the parts made of unobtanium? Maybe I just don't know what these things cost.
Just curious.
05-09-2006, 09:40 AM
Moderator
Just curious.
OE Honda N/Z/S components are next to impossible to find. For a head rebuild (for instance) you pretty much have to either have your valves reground or you buy custom new ones. This goes for the cam as well as everything else. These little cars do have a following so there are suppliers for these parts and services, but the following is small therefore you can't run down to NOPI and buy a new cam for your Z600.
05-09-2006, 09:55 AM
This is exactly the problem. Honda seems to have broken the mold after this making this engine. They didn't make a 600cc engine for a motorcycle until around 10 years later. I'm positive the parts won't match.
There is a guy who sells NOS crankshafts for around $1000. He's also selling the green car. I have no idea HOW he managed to get all of these old crankshafts. I can only guess he worked for Honda or something in the past and snatched them all up on the way out.
I did find a website in Taiwan that claims to sell new pistons and camshafts for the n600. I emailed them and had no response. It kinda pisses me off too because I spent all night finding that site.
the guy who sells the crankshafts also sells pistons 1mm over bore for rebuilds for around $600. When you add it all up suddenly $2k-$3k for a rebuild starts to make a lot of sense.
I might end up doing this eventually, assuming my engine craps out on me.
The other option is to try to get a d15z1 in there, or maybe an engine from a CRX HF. That woudl require lots of custom work and I'm honestly not really qualified to do that much work.
05-09-2006, 11:43 AM
Instead of restoring it, why
Instead of restoring it, why not convert it? It would make an excellent electric, and the unique factor would be even higher.
05-09-2006, 11:49 AM
Re: Instead of restoring it, why
I may go this route in the future, but for now it's going to be a gas driver.
to convert this I'd have to outsource a new transmission, make a custom shift linkage, and have custom axles made. This engine/tranny combo is not really versatile.
05-09-2006, 03:01 PM
another engine idea
for a new engine, how about a honda cb400f v-tec engine? you would have to find one and have it shiped from japan, but they are 400cc dohc water cooled 4 cylender v-tec's that operate in either 8 or 16 valve modes, it would be smaller, lighter, and I'm pretty sure more powerful then your stock engine.
by the way, I've been told that the n600 has a chain drive, is it front or rear wheel drive?
05-09-2006, 03:42 PM
#19
Re: another engine idea
n600 is not a chain drive. You're thinking of the s600. My car is front drive. the s600 is rear I believe.
I'm going to look at the cb400f v-tec... do you have any links about it? physical size, etc?
05-09-2006, 07:33 PM
#20
Besides the single-row overhead cam drive chain (between the cylinders), the <a href="http://www.honda600coupe.com/Honda_600_Sedan_Shop_Manual.html">shop manual</a> shows two single-row chains that connect the left-hand end of the crank shaft to the clutch/transmission main shaft. From there it looks like gears that eventually drive a normal-looking differential with CV joints to the shafts. It's a pretty neat setup.
