Incorrect System Stored "Pervious Odometer" Value - Fuelly Forums
Old 06-05-2023, 12:36 PM   #1
Question Incorrect System Stored "Pervious Odometer" Value
Originally Posted by denhurt View Post
FIXED!
Log into your Fuelly account on a browser.
Locate the vehicle in left column.
Scroll down to LOG BOOK
Select [View all Fill-ups]
Find the entry with incorrect odometer reading
Select EDIT
Enter correct odometer reading
On Fuelly app, Sync All Data
Done
I've been using aCar to track mileage and expenses, etc., for many years.
One car has the "Pervious Odometer" incorrectly set. aCar will not allow the entry of Expenses or Services with mileages less the "Previous Odometer." How do I correct that "previous odometer" that is not part of the actual record. Where is it stored as it is "system" entered when I try add a new record?
The first picture of the record being added showing the incorrect "pervious odometer" and the second is actual mileage for the expense.
Kenn
ID:	2871   Click image for larger version
Garris1 is offline   Reply With Quote
Old 06-06-2023, 07:29 AM   #2
Originally Posted by luckypo View Post
Check the car settings in the app, also change the mileage. If it is possible to delete or edit the "previous odometer" entry, do so and enter the correct value.
I didn't find a "car settings" selection in the app. How would I identify it?
"Previous Odometer" is filled in by the app. It is not a field that the user can modify. At least, I can't. I don't know where it's set or stored. Refer to the attached picture.
Old 06-06-2023, 08:21 AM   #3
Smile
I made a backup of all the vehicles. Then cleared data and cache. Followed by deleting and re-installing the app.
Somewhere in that process the erroneous "Previous Odometer" value was changed to the actual last odometer value and I was able to enter an Expense record with the correct odometer value.
Thanks for the suggestions.
Kenn
Old 06-13-2023, 09:07 AM   #4
I finally found the location of where the new record Previous Odometer value is stored.
It's saved in Vehicle Data under the field name Last Odometer.
If only I had known...
