CRX Hf shell/VX engine/tranny? - Fuelly Forums
Old 04-21-2011, 07:41 AM   #1
sebass's Avatar
Question CRX Hf shell/VX engine/tranny?
Hi guys. I was thinking about buying crx shell ($800) and buying brand new vx engine and installing it into crx hf body. Engine cost is $350. Not sure how to go about getting a HF tranny. Maybe brand new aftermarket tranny to HF specs? Is there something like that out there? Is VX tranny or are there any other honda tranny's manual that are same gear ration (tall gears) as HF gears? How much do u guy think installation cost (rough estimate) would be for all that? Is this worth a hassle? How many MPG would this frankenstine get? I figure VX gets 49 but it's 200lbs heavier then CRX HF so VX engine can get 52mpg+ if it would be in CRX body? Any replays would be very much appreciated.
sebass is offline   Reply With Quote
Old 04-21-2011, 09:45 AM   #2
VX_Arky's Avatar
Re: CRX Hf shell/VX engine/tranny?
Tried to send you a PM sebass, but your inbox is full. You need to delete some of your PM messages and clear some space it you want to be able to receive any more PMs!!!
VX_Arky is offline   Reply With Quote
Old 04-21-2011, 11:32 AM   #3
GasSavers_Erik's Avatar
The CRX would be more aerodynamic than the VX, but then you'd also need to buy the VX ECU, EGR box and likely a wiring harness. A decent honda shade tree mechanic would likely charge you at least $600-1000 for the labor of the swap and custom work if you delivered all of the needed parts to their shop.
Old 04-21-2011, 11:33 AM   #4
Brand new VX engine for $350....
GasSavers_viperguy is offline   Reply With Quote
Old 04-21-2011, 12:00 PM   #5
sebass's Avatar
Erick thanks. How much ECU and ERG box cost? So basically this may not make too much sense right?
Viperguy....yes brand new vx engine for $350.
Old 04-21-2011, 12:08 PM   #6
I honestly don't know how much they would go for.
It might make sense if you could do all of the work yourself.
Old 04-22-2011, 05:29 AM   #7
I took a look around craigslist and you may be able to find one for a couple hundred. And if you can do the work on this, go for it, very worth the extra mpg's!
Going GTO once I finally get a job. Stayin pontiac all the way.
NotYourDay is offline   Reply With Quote
Hi new accord in town RedAccord02 Introduce Yourself - New member Welcome 9 07-09-2010 12:12 PM
yet another WAI experiment: Related discussion bowtieguy General Fuel Topics 26 02-08-2010 07:57 AM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 03:27 AM
