How much does weight have to do with fuel economy??? - Fuelly Forums
Old 06-08-2006, 03:19 PM   #1
Compaq888's Avatar
I think 35-40 lbs of weight reduction will help my fuel economy on the street, what do you guys think??
Old 06-08-2006, 03:24 PM   #2
95metro's Avatar
Purely based on hearsay and without a shread of solid evidence (which I have not looked nor asked for) is this:
The rule of thumb from engineers on this issue is that with every ten percent of weight reduction mileage is improved by about 7%.
95metro is offline   Reply With Quote
Old 06-08-2006, 03:34 PM   #3
FE nut
diamondlarry's Avatar
If my math is right, 45 pounds would be about 1.5% of a 3000 pound car. This would translate to 1% or less improvement in mpg?
2007 Prius,
Team Slow Burn
Old 06-08-2006, 03:34 PM   #4
Compaq888's Avatar
Darin removed most of his interior and it looks like his mileage went up. Can anybody do some scangauge testing on this or present scangauge data???
Old 06-08-2006, 03:37 PM   #5
Compaq888's Avatar
It's not actually 45, it's around 55-60lbs. i got some other stuff removed.
Old 06-08-2006, 03:39 PM   #6
95metro's Avatar
But he (Darin) had a few other mods as well + temps are on the rise + the stuff was only out for a few runs + even a measly hundred pounds is a hair over 5% of a Swift-clone's weight (that equals a 3.5% FE increase according to the rule-of-thumb) + CODFISHing like a madman = a 75+ mpg tank.
Old 06-08-2006, 03:46 PM   #7
Matt Timion's Avatar
I don't think he was actually talking about you compaq. I believe his 45lbs figure wasn't in reference to you.
That being said, the EPA says that every extra 100 lbs is 1-2% decrease in fuel economy.
Remove Excess Weight
Avoid keeping unnecessary items in your vehicle, especially heavy ones. An extra 100 pounds in your vehicle could reduce your MPG by up to 2%. The reduction is based on the percentage of extra weight relative to the vehicle's weight and affects smaller vehicles more than larger ones.
You also realize that there is a cutoff for this type of statistic.
I think if you really want to save weight you need a smaller car. 30-40lbs isn't going to do much in terms of fuel economy. I even think 100lbs isn't going to be noticable.
Old 06-08-2006, 03:56 PM   #8
Compaq888's Avatar
You also realize that there is a cutoff for this type of statistic. [/LEFT]
I think if you really want to save weight you need a smaller car. 30-40lbs isn't going to do much in terms of fuel economy. I even think 100lbs isn't going to be noticeable.
100 lbs is noticeable. In 2004 when the car was stock it would run 17.03 was my best run with full interior and no spare/jack.
Then I removed the passenger seat and the rear seats, which was about 65-70lbs and then ran 2 runs. Which were 16.94 and 16.96, that almost a full tenth. A tenth is about 10hp difference in racing terms. The moral of the story is all that stuff removed was about 100 lbs, which made the car quicker.
Old 06-08-2006, 03:57 PM   #9
95metro's Avatar
I think you're right, Matt. Any mod probably varies hugely car to car. If a car starts off heavy you're going to have to remove a lot more weight to see any noticeable difference in FE. You can see a 1-2% (or higher depending on circumstances) difference in FE trip to trip.
Could it also have been that you got better at launching the car? 1/10th seems minimal to me - I know it's not in the racing world, but if your reaction time got better then couldn't that account for the same time? It could have been the weight too, but the driver accounts for a lot.
Old 06-08-2006, 03:59 PM   #10
Compaq888's Avatar
A 100 lbs will probably mean nothing on the freeway but 1/4 mile racing not constant speed, it's all about accelaration. Driving on the streets is all about accelaration most of the time.
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 11:11 AM
