Milage keeps decreasing with every tank... - Page 3 - Fuelly Forums
Old 10-21-2007, 03:15 PM   #21
Get in better shape or get some easier gearing for the hillz,
Old 10-21-2007, 06:36 PM   #22
1993CivicVX's Avatar
I was riding with a group of fairly solid riders this summer. The bike I was using didn't have a granny gear. Everyone else spinning up the hills nice and slow at a good high RPM and I'm struggling to maintain 8mph. By the end of the summer I was able to tackle the big hills and manage to keep from falling under 8mph. (any slower than that and the RPMs get too slow and then it sucketh the big time.) It was challenging and all, but biking is fun; the hardship of hills seems worth it to me.
three stripes the charm!
Old 10-21-2007, 07:47 PM   #23
GasSavers_Minger's Avatar
Hmmm...tempting. Only other thing I can think of that would stop (or make me getinto freaking good shape) is that usually I have a break in the day - sometimes 3-4 hours, so I go home...either I toughen up and get in shape or die on thew a...
Maybe in the spring...but II just keep postponing working out :/
P.S. I must be a wierdo as I think just because a guy can afford to do something, doesn't mean he should. I can afford to buy 100 gallons of gas several times a month, pour it on the ground, light it (or not)... but I don't think I should.
GasSavers_Minger is offline   Reply With Quote
Old 10-21-2007, 08:46 PM   #24
Start now!
Old 10-22-2007, 03:31 AM   #25
Originally Posted by Minger View Post
My MPG seems to be fluctuating a lot, despite my trips being the same - I once hit 41-42ish, but my last fill was barely 35...its weird, because the trip is generally the same - from my house, its about a mile or two (engine warms up in this time), and then a lot of hills to school...
The hills I drop to neutral, generally 40-45ish at the peaks and a max of 60 on the downhill, then rev match (or at least try to, no tach...yet) and let the speed bleed off to around 40ish when I get to the top of the hill, but sometimes lower, as the car doesn't force itself to downshift until I drop below 30mph.
Anyways, maybe its just me or the weather, as its getting colder now...and if its me, the scanguage should come in tomorrow.
I just brought it in for an inspection and oil change today as well.
And how do I get the sig? Or does that just come with time...
Join the club minger! My driving improves and my mileage goes down. What fun! I want to know how come some people have a 90 day running average. Not that I have anything to show off.
Old 10-22-2007, 07:30 AM   #26
A few things to check when your mileage starts dropping would be: Air pressure in the tires, brakes dragging check for warm wheels and rims, Oil getting close to the end of its life needs changing, exhaust pipe soot buildup from faulty injection, fuel leak, colder temperatures, low engine temps from faulty thermostat - to name just a few things.
Old 10-22-2007, 09:10 AM   #27
Just got inspection and oil changed...the rest should be decent as its still a fairly new car, psi is 43ish cold
one more question - if the scanguage gives me the current mpg as around 100+ when in neutral, and 9999 when in gear when coasting, should I continue to coast in neutral or in gear?
Old 10-22-2007, 10:08 AM   #28
The coasting question is a difficult one...you will use no fuel coasting in gear (on a manual) but some coasting in neutral. I usually cost in gear to a stop and neutral when I don't want to slow down.
Old 10-22-2007, 11:27 AM   #29
Weird. You'd think they'd have found a way to shut it off when in neutral, but then again, I might just not know what I'm talking about. Which I don't.
I guess I'll AB it with my first trip today and when I go back to school in half an hour...which ones higher.
Old 10-22-2007, 11:42 AM   #30
You can always shut it off yourself,
CRX HF Transmission Rebuild GasSavers_DaX General Fuel Topics 35 09-15-2010 03:37 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 01:18 PM
Car Heaven Canadian program. Emissions minic6 General Fuel Topics 43 06-11-2007 05:58 AM
Innovate LC-1 WB O2 sensor Installed CoyoteX General Fuel Topics 12 04-15-2007 04:26 PM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 05:43 AM
