have you told them that you are getting around 40 percent over EPA?
I had my tires realigned and the manager wanted to talk to me about the stuff I had done to my car to get such good mileage. I told him that the alignment was killing me. I was only getting 34-35 MPG. my EPA estimate says I should get about 25. the big 38 on the side of my car does get some attention especially since it is an atuo trans. I would say to the mechanic and the tire supplier, if it couldn't handle it then why is it printed on the side of the tire? I still stay a little below what mine is rated. I keep mine at 45 or so and side wall is 51 (odd numbe isn't it) |
I tried that, and to be fair, he's always really busy and hasn't had a proper chance to explain to me why he thinks it's a problem. I don't really take his concern seriously, so haven't made a point of getting it out of him. He is interested to see what a belly pan would do, but is also a little freaked by the idea of a grille block.
Didn't I see in one of the WAI threads that the insight's WAI is behind the radiator so high power levels overwhelm it and cools the air off again? Has anybody tried doing that themselves?
Got my SG2 today and my IAT is 112 F after about 15 miles of driving (drove to fill up and zero the SG2). Not positive that's steady state or not, but 112 F seems about about what I'd expect based on my oh so sophisticated "touch the duct test" from the other day. What temp should I be aiming for anyway?
Based on what I'm seeing in the WAI threads, 112 is lowish. Maybe the manifold heat shield isn't getting hot enough? What if my WAI was the heat shield? Be easy enough to do.
From reading other posts there seems to be a bunch of others that say around 180 is good, and almost everyone says that over 200 the performance suffers too much.
-Jay |
I removed my manifold shield and repositioned the split duct to cover the same area. It didn't like all the manhandling, but this is only temporary anyway. I ran the O2 sensor out the same way the original did.
https://www.fuelly.com/attachments/fo...a5bf1e43f6.jpg |
if you already had a heat shield, you do have another option.
many that already have heat shields simply unbolt the top of it and bend it back. then place the ducting directly into that. so far this year, the highes temps I have seen have been in the low 160s so it takes time and what is the average daily temp. the delta that I am seeing on average is 70 degrees over ambient if that helps |
I wish I could, but I don't want to screw with the original in case I need to avail myself of the warranty. In that case, I'll rip my WAI off and bolt it back on. I'm actually keeping it in my trunk and have tools to reattach ti should I fail on the road.
