I still have my cheapie eBay autodark in my shop - I pull it out when someone else wants to observe me welding. |
Anybody know if the harbor-freight ones are any good?
Yep, I was looking for an autodark kind. I was planning on snatching up one like this: https://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=020
For what you're doing, I guess that will work. That's like my eBay helmet. The problem with these helmets is that the light sensor is small and there is only one - what happens is that while you're welding, if your hand or something is blocking the light from getting to this sensor, it will flash clear. This also happens on low amp settings (which you probably won't use unless you're tigging something thin). My Miller helmet has four sensors and a larger viewing window. It is also capable of staying dark for inverter machine arcs, and will stay dark down to 5 amps of current. Another difference in the helmets is the material - my eBay one is very thick, stiff plastic and gets uncomfortable rather quickly. My Miller helmet is made of a thinner, softer plastic which is more flexible and comfortable.
In the light of this being a budget project and the small amount of welding you're doing, I think you will be fine with the eBay unit. If you think you'll be welding a lot more in the future, get a good helmet. |
Thanks - that's good info. Amount of welding will probably be minimal, and higher current as you guessed. So I'll see if I can snag one of these and I'll report back about how it turns out.
It was welding day in ForkenSwiftland! Fun, fun.
Welding helmets
Forgive my ignorace, but what's wrong with ye olde fashioned welding helmet?
https://www.allproducts.com/manufactu...ing-helmet.jpg I got one for $10AU and it's great. I even used the crummy plastic lens for a while but it was a bit light so I replaced it with a glass lens and spatterguard (about another $10AU) which was even better. Then again, I may be a retro grouch/tightarse since I also use an arc (stick if you prefer) welder :D Nice to see your build is coming along well anyway. **edit** On closer inspection that first photo was of a crappy helmet without a flip up lens. |
Hello all I am a newb and started reading this thread... Wowo its long.. anyway what are the current specs on this car how fast will it go and how far?
Has there been any talk on adding solar panels or a diesel generator for extended range? Or maybe even a small gas motor for high way speeds? |
Discovered another Suzukiclone conversion today, just down the highway in Toronto:
https://www.austinev.org/evalbum/imgm...pg&w=300&h=224 https://www.austinev.org/evalbum/1219 Looks like they did a 4wd conversion while they were at it! |
As always, great work. |
