It took an good afternoon. I dont have any "written" instructions, but I can answer your questions.
ok, I'll keep that in mine when the time comes, thx
Gary,
You need a really powerful air compressor to make the"air vac" work. You are better off to get a real vacuum pump to do the job. |
To the canadians: can you guys still get R12? Gary |
At least 90 psi with at least 6 cubic feet per minute capacity. The air compressor will need to be fairly big (5 gallon or larger) to deliver a sustained blast of 90 psi.
Heed the advice of someone who has been where you're going. Forget the Air-Vac and get a small rotary vane vacuum pump. The one I bought was a FJC model 6908. It is a single stage pump with 1.5 cubic feet per minute "suction". It does the job and only cost $99 plus shipping. As to the ambient outside temperature "needed" to draw a deep vacuum. A strong vacuum can evaporate and pull out the water in the A/C lines regardless of the outside temp since the volume of air in the Civic system is relatively small (PV=nRT). Higher outside temperatures make it easier to draw a vacuum with a less powerful vacuum source (like that Venturi air vac you want to use). My FJC vacuum pump worked fine and it was only 50?F outside when I originally worked on mine in April 2006. As I mentioned earlier, get the proper tool for the job and make it easier on yourself - especially since you have not done the job before. But as many have said YMMV. |
I have a 20gallon tank. Yeah, I will look into the rotary vacuum pump.
Where can I get one at that price? Thanks, Gary Quote:
Just take the mfg & model # FJC 6908 and do a search on Google or yahoo. I bought this pump from an internet seller - not ebay as I recall anyway. You should be able to get one for no more than $125 still. Not many rental places carry these but you might get lucky find one to rent.
As for retrofitting a Civic without A/C, I have found this to be quite an easy affair. From my experience, everything is pretty much plug-and-play when it comes to installing a FACTORY A/C on a car that did not come with A/C wen new. The same probably cannot be said about aftermarket units. |
