StorminMatt |
11-04-2007 01:28 AM |
Originally Posted by mrmad
(Post 79778)
I converted the Nissan I had and it was working fine when I sold it 2 years later. I converted the wife's 4runner at the same time and 4 years later the AC is still cold. Neither produced cold air as well as they were with R12, but they are cold enough.
Then again, 'cold enough' is a subjective thing hat depends on a number of factors. One is obviosly climate. It has been my finding that converted R12 systems REALLY start to peter out at around 90-95 degrees. And if we are talking 100+ degrees, forget it. Here in Sacramento, 100+ degrees during the summer is not too uncommon. And under these circumstances, the converted R12 system that I had in a Civic some years back was virtually useless.
The kind of driving also made a difference. R134a is actually quite a bit harder to condense than R12. In fact, the condenser itself is probably one of the BIGGEST differences between a system designed for R12 vs R134a. Because of this, converted R12 systems tend to not work well when the car is not moving fast enough to move LOTS of air through the condensor. Trying to get cold air when sitting in traffic is a lost cause.
Finally, there is heat tolerance. Let's face it. Some of us just take it better than others. And I don't take it too well. In fact, I find that MANY A/Cs just don't cut it even with R12. I would HATE to see how they would perform with R134a.
But the bottom line can be summed up rather quickly: if you are installing an A/C in a car that has none, want to run R134a, and have a choice between using a system designed for R12 OR R134a, why would you choose to run an R12 system and retrofit it rather than running an R134a system (which will work better in the first place)?
