It works because the wheels are able to keep the motor running. Instead of the motor running and moving the wheels, it works vice versa.
EOC is a great way to boost Fe, but it is dangerous and illegal in most states. My brake pedal goes stiff after a half a minute of so when using the brake while coasting down a hill. Some hills around new england are quite long and steep and without using the brake you could easily get up to speeds of excess of 80 mph plus, and I don't feel comfortable at that speed with a stiff brake pedal. I say nay to EOC.
BTW it is "don't taze me dudebro." |
does EOC count if your coasting down a hill and the car only idles at 100-200 rpm? :D i dunno what causes that but i like it. scary part is that it runs as smooth as if it were at 800 rpm...yet its eerily quiet
DaX -
CarloSW2 |
My only thing about EOC is that I always end up having to go up a hill after the coast, and I don't know at what point to start accelerating again for the hill. Because if I wait too long to go back in gear I will waste gas going up the hill because I won't have enough momentum for it. |
slimreynolds -
Only you know your road, so only you know what will work for you. YRMV (Your Route May Vary), CarloSW2 |
And it is only as dangerous as the driver, the brakes are firmer when boost runs out, but I can still lock them up when the boost is gone (and/or downshift and/or use the handbrake). It is just a matter of practice (away from real cars please, you are basically learning to drive again) Standard Disclaimers Apply: https://www.gassavers.org/showthread.php?p=38813 |
hah yea thats the way with me on a cetian long exit ramp. can coast for about a 1/4 mile then theres this hump and a slight grade at the bottom. after coasting your around 55 at th ebottom but the hump knocks it down to like 45 then it seems as if you jamming on the gas to get up to 55 again cuz of the slight grade |
yea hes right about the coasting in gear. i just wanan know how the cop knows if you were in gear or in neutral...:confused: some cars you cant overcome the no pressure (takes a crapload of force to stop my truck with the booster empty) thers no way i could lock the wheels. the handbrake only locks the rearwheels which any slight turn of the front wheels is gonan put you into a skid/spin. that and it takes up to 30 meters to stop the adverage car from 30 mph. with only ther handbrake(longer if wet). thats only true if it works and the cables dont snap.:D while it may be true for some cars, not all cars are equal.... |
Well a simple vacuum pump and vacuum switch can fix that if you don't feel safe stopping the car without assist. A larger vacuum volume can buy you more time but I would reccomend the electric vacuum pump if your car NEEDS vacuum to stop.
The pump only needs to kick in when the vacuum gets too low, then it can shut off. |
