clutch case cover is bent, what to do? - Fuelly Forums
Old 05-07-2006, 06:23 PM   #1
Matt Timion's Avatar
Admittedly I don't know much about engines. Hell, I don't know much about cars. I've never even changed my oil before, but I'm planning an engine swap. Go figure.
Anyway, I was mounting my new transmission on my new engine today and I noticed that the bottom of the clutch case cover is bent. It looks like the engine was resting on the clutch case cover at one time.
Does transmission fluid only go in the gear area of the tranny and not where the flywheel/clutch are? If my cover is bent on the bottom should I replace it just to keep the dust/etc. out of the clutch/flywheel area?
if I'm going to replace my clutch case cover, should I just replace my clutch and flywheel too?]
I would post pictures but the camera isn't here.
###EDIT###
The part that is bent is #1 in this image:
Old 05-07-2006, 07:28 PM   #2
Some pictures of the bent
Some pictures of the bent cover:
Old 05-07-2006, 08:29 PM   #3
philmcneal's Avatar
wow didn't know you were as
wow didn't know you were as car illerate as me, at least your first task is a big one and hope it all goes well for you! if you can do this yourself man then you can do a lot of things on your own car.
I know the technical aspects of an engine, but to work on it I'm clueless and timid.
Right now I want to clean my 12volt batteries but am afraid.
Old 05-07-2006, 08:33 PM   #4
He's not, of course, but he doesn't put enough miles on it to change the oil,
He did paint the whole thing himself after all, and did a damn fine job, I might add.
Old 05-07-2006, 09:41 PM   #5
GasSavers_Diemaster's Avatar
Re: Quote:wow didn't know you
of course u'd never know that b;c he didnt change his avatar :P
i would replace ti just for the hell of it. i mean after all u dont want dirt in your oil and **** ur "new" motor and or trany.
I ♥ my EM2
Need this stuff gone!
https://www.honda-tech.com/zero...67053[/B]
GasSavers_Diemaster is offline   Reply With Quote
Old 05-07-2006, 09:52 PM   #6
I found a thread on honda-tech about this cover. Apparently some people take it off and are fine. Others insist on it being there. I'm going to see how much work it is to remove (like if I need to remove the oil pan to do it, etc. If it's an easy task I'll just remove the one from my existing engine and put it on the new engine.
Old 05-08-2006, 05:35 AM   #7
Moderator
GasSavers_DaX's Avatar
I'd be willing to mail you
I'd be willing to mail you one if you need it.
I surely wouldn't go without it. Any debris gets caught up in there...yar
Old 05-08-2006, 05:46 AM   #8
Re: I'd be willing to mail you
Do I need to remove the oil pan in order to remove the cover?
I should be able to just grab one off of a junkyard car for a few bucks.
Old 05-08-2006, 06:50 AM   #9
Moderator
There are a few bolts that
There are a few bolts that hold it to the transmission (I think even one of them sandwiches the plate between a bracket and the transmission bell housing) and I think two 10 mm bolts that hold it to the engine (these bolts point "up" instead of sideways like the ones going into the tranny). Oil pan removal is not necessary.
I've gone to change a clutch before and unbolted everything but this plate and was yanking and pulling on the transmission, only to look down and see that I had forgotten to unbolt this flywheel dust cover and had bent it all to hell.
Just go to the junk yard and pull one...you'll figure out how to get it off.
Old 05-08-2006, 07:02 AM   #10
Re: There are a few bolts that
This is comforting to know I can do it easily. I might have to wait until the engine is in teh air before i can replace the part due to very limited space on that pallete.
issue with image in signature banner brian83 Fuelly Web Support and Community News 5 09-13-2010 03:33 AM
SMS fuelup went to wrong car todd Fuelly Web Support and Community News 4 03-17-2010 02:31 AM
Kansas City GasSavers_katman General Discussion (Off-Topic) 1 05-27-2006 09:01 AM
