Finished the underpan on my VX - Page 3 - Fuelly Forums
Old 09-10-2007, 08:31 AM   #21
It's aftermarket.
Here's a crappy cameraphone pic I just took:
Close to stock, but I can see where it "scoops" air and creates downforce.
gamby is offline   Reply With Quote
Old 09-10-2007, 09:48 AM   #22
GasSavers_TomO's Avatar
With that lip, you could use it if you don't have an OEM one handy. I'd personally block those holes on the sides as it's just letting air hit the front of the tires wich isn't as efficient as it could be.
Honda Civic VX Info/Links
Old 09-12-2007, 07:15 AM   #23
GasSavers_civicminded's Avatar
For all you guys that did the bellypan with self-tapping screws:
How did you take care of, or is there, intrusion into the passenger compartment? I have enough choroplast to do the pan, I also now have a secondary ride so I'll be able to put her out of commision long enough to do the pan (spacing it out over a couple days).
Thanks for any input you can provide.
www.onetruth.com
www.sohchonda.com
GasSavers_civicminded is offline   Reply With Quote
Old 09-12-2007, 07:29 AM   #24
I think if you go down the center of the car you should be fine as well as intrustion goes. There is also the pinchy space on the sides that doesn't go directly to the cabin. *shrug*
Old 09-12-2007, 07:42 AM   #25
There are reinforcements that run parallel to the exhaust tunnel that I screwed into for attachment points. The screws were no longer than 3/8" and the reinforcement was about 1/2" so there was no intrusion into the passenger cabin. Along the outside edges I used the existing holes from the side skirt attachments to sandwich and secure the coroplast.
Old 09-12-2007, 09:21 AM   #26
Thanks for the quick replies!
I feel much better about doing this mod now - I've got 318k on this chassis (not as much as basjoos, but I might catch up! Well, eventually. ) and would like to keep it going.
www.onetruth.com
www.sohchonda.com
Old 09-13-2007, 06:17 PM   #27
I just made sure that they intruded in areas that were out of harms way - like under the seats . Also, I took full advantage of the frame and just drilled right into that.
( I hope I did not weaken it in any way . That would have been really dumb.)
Nerds laugh at me is offline   Reply With Quote
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
U.S. Cars Show No Fuel-Efficiency Gains in 2006 MetroMPG Automotive News, Articles and Products 3 04-26-2007 11:15 AM
New member from Akron Ohio, 2001 Saturn Sl1 Golf3r Introduce Yourself - New member Welcome 28 04-10-2007 03:22 PM
