FE Difference DX vs HF Motor in CRX HF? - Fuelly Forums
Old 10-02-2007, 12:17 PM   #1
I was at the mechanic's shop checking on the starus of my D15B6 motor and again things are at a standstill. They can not find the wrist pins for the pistons. They have a JDM engine sitting there for a DX. It would be less to get this swapped into my car than the rebuild would have cost. How much decrease in
FE could I expect using the 16 valve motor with my HF Tranny in my 88 CRX HF?
I currently am getting 32 average around town out of a 90 corolla 3spd auto old EPA 26 - 29
FritzR is offline   Reply With Quote
Old 10-02-2007, 12:27 PM   #2
Swap the DX engine in there with you HF tranny if it's your only option. Your gas mileage won't be as good as the HF but it will be better then the corolla.
korax123 is offline   Reply With Quote
Old 10-02-2007, 03:02 PM   #3
If that's what you've got to work with, I'd go ahead. My guess is that you will see a 5% maybe 10% decrease in mileage, but I think it will be closer to what you were getting, or could get, than not.
Old 10-02-2007, 03:12 PM   #4
GasSavers_Ryland's Avatar
I wouldn't put the DX engine in, as it's power curve is going to be all wrong for your tranny, you would be better off trying to find a free or cheap engine on hondatec.com or on Ebay from a CRX HF, as people are already ripping them out in hopes to kill them self while driving fast, it sounds like your mecanic is rather irresponsible,
Old 10-03-2007, 05:41 AM   #5
I somewhat agree w/ Ryland. I bought a '95 Civic DX hatchback w/ 68,000 miles on it about 7 months ago. One of the first things I did was swap the tranny for a CX/VX tranny. Looking at the hp and torque numbers for the DX, I figured it would drive about the same as my former '95 VX. Well, I was wrong. The power curve is key. For the DX, it's all in the higher RPMs. Whereas my old VX had lots of low end grunt allowing me to climb substantial hills in the taller gears without a problem, my DX w/ the CX/VX tranny is completely different. I have to downshift on those same hills.
That said, it was still worth swapping the tranny b/c I probably get 6% - 8% better FE, and I consider the power loss a fair tradeoff. If I had to do it all over again, though, I would have waited to buy another VX w/ low miles rather than going w/ the more plentiful DX and a tranny swap.
Old 10-03-2007, 10:02 AM   #6
So I guess if I need to go with the d15b1 motor from the civic hatchback that has 83 ft/lbs of torque at 3000 rpm like the hf motor?
Old 10-03-2007, 03:12 PM   #7
If you have the DX bottom and the HF top, I think your going to be pretty close to the same as a complete HF engine. The only difference at that point would be the dish in the pistons and that is pretty miniscule. If the bottom end and top end are available, I'd go with that, you've probably been charged enough, already, without starting over on another engine. MOO
Old 10-03-2007, 04:58 PM   #8
Thanks, that's what I did. And they are eating the costs so far since they could not do what they estimated. The had all the parts they needed sitting right there for a month.
Old 10-03-2007, 05:11 PM   #9
mrmad's Avatar
Are you sure the valves will not hit the pistons? The reliefs are there for a reason.
Old 10-04-2007, 09:29 AM   #10
Well if there are 4 valve reliefs in the piston and only 2 valves in the head I think it's a non issue
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 07:03 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 05:20 PM
Interesting article about aerodynamics McPatrick General Fuel Topics 0 06-23-2007 06:11 PM
Buses = FE saving minic6 General Fuel Topics 1 06-13-2007 04:28 PM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 03:27 AM
