02-27-2006, 04:21 PM
Moving the O2 sensor
Please stop me and point me to the correct thread if this has already been covered. My mind has been focused on increasing my mileage lately (I'm normally a speed freak kinda guy), cause I'm tired of all the money I toss down the gas tank filler.
Reading through a number of articles, I noticed some complaints about the O2 sensor reacting too slowly to changes. In some vehicles, I've noticed that the O2 sensor is mounted a good deal downstream. Why not move it more upstream? Doing so will increase its response time.
Also, having a A/F guage mounted in some of my vehicle (mostly just to make sure I'm not running lean under high boost conditions), I've noticed that as the O2 sensor gets older, it also reacts more slowly. So maybe that factory recommended 30k miles isn't such a bad idea after all.
Any thoughts or comments?
Anger is a gift!- Zack de la Rocha
02-27-2006, 05:26 PM
Re: Moving the O2 sensor
I think it's a good idea. Honda did this with all of their high gas mileage vehicles. On the Civic VX, CX, HX, STD, and some of the CRX HFs, the exhaust manifold is made in such a way that the o2 sensor reads the exhaust right away. On the other cars it is about a foot down the pipe.
I'm wondering if it is not a bad idea to swap the exhaust manifold (along with a new o2 sensor) to one that is closer to the head.
02-27-2006, 05:45 PM
also there are different
also there are different types of o2 sensors. There are narrowbands and widebands. Widebands are really good.
02-27-2006, 05:50 PM
True, but unless you build a
True, but unless you build a board that converts the wideband voltage range to the desired narrow band, you're not going to be able to easily use the stock ECU. While moving the O2 sensor farth upstream will do nothing but increase the ECU's ability to better control the fuel, assuming the CPU in that ecu is fast enough.
Though I should note, some
Though I should note, some ECUs do use a wibeband O2 sensor, such as the 92-95 Honda VX.
02-27-2006, 05:56 PM
Are you not equipped with
Are you not equipped with wideband?
02-27-2006, 06:14 PM
Re: Are you not equipped with
I have the stock wideband in the VX motor and then an "aftermarket" wieband I use for tuning in my other cars. But under normal operating conditions, the B18c and the Volvo use a narrowband O2.
02-27-2006, 06:18 PM
Ah, well, I forgot about
Ah, well, I forgot about those other cars, cuz they suck I guess. But good to here you're using the wideband with the z1,
What wideband do you tune with?
02-27-2006, 06:30 PM
I tune mostly with the
I tune mostly with the Innovate LM-1 system, but I've also used some home-brew VX and VW based wideband systems.
I really wish my Volvo got better mileage, but I can never seem to get better than 12-13 MPG cruising at 130mph.
02-27-2006, 06:34 PM
I noticed someone trying to use the vx ecu as a controller way back, is this what you mean?
No need to be cute.
