MPG loss due to supercharger - Page 2 - Fuelly Forums
Old 08-21-2010, 02:44 PM   #11
Re: MPG loss due to supercharger
You forgot Spirit, Citation, and Chevette!
Old 08-21-2010, 02:47 PM   #12
I imagine this one is fast, and handles really well...
Old 08-21-2010, 07:40 PM   #13
Must be pretty fast, I see they put a big wing on it.
Hipermiler
#47 on my way to #1
Old 08-22-2010, 05:59 AM   #14
I tried it with my GTP, and just noticed that the car was a pig. That is about it. You could always go with a bigger pulley if you wanted.
Old 09-16-2010, 05:41 PM   #15
SeanHenry's Avatar
You have the taller gears in the Buick so it will hurt off the line but should be good for MPGs.
My first question is what are you using to scan and program the car?
Have you calibrated the MAF?
Instead of removing the Supercharger belt turn down the Boost Bypass valve here is the first how to I found for it http://www.zzperformance.com/grand_p...les1.php?id=56 Instead of pushing it in you will want to move it out some so boost does not come on as easy.
SeanHenry is offline   Reply With Quote
Old 09-16-2010, 11:26 PM   #16
Site Team
I'm using a HP Tuners device. Pretty slick, but it's been hiccuping a bit lately.
The MAF is actually the larger Cadillac unit, so it was recalibrated when it was changed. And the supercharger is the later, larger version (I forget which "gen" it is, but it's not the '98 version)
And the Buick has the taller gears from the factory, but mine were swapped out for the shorter gears. The car used to do a lot of city driving. Now that I do all highway, I wish I had the taller gears back again. Besides, without racing slicks, the extra gearing is useless at the racetrack (actually counterproductive) off the line because of the traction loss, it would be better to have the taller gears and stay in 1st longer - I don't need any extra torque multiplication.
-BC
Old 09-16-2010, 11:28 PM   #17
Site Team
I have 3 pulleys, but if the difference between the pulley I'm using and no belt at all is only 1/2 MPG, then I would think that changing from 3.4" to 3.5" would be useless. I'm actually thinking of putting my 3.2" back on, and I'm guessing that will have no noticeable difference.
Old 09-19-2010, 07:51 PM   #18
SeanHenry's Avatar
Can you post your tune and a scan of your car I also use HPtuners for my can so I can give it a look and see if I can give any advice.
Old 09-20-2010, 12:23 AM   #19
Site Team
I think my hardware has been on the fritz lately, I haven't hooked it up in a while. I was getting more and more partial flashes (wound up being stranded a few times), so I've stopped using it. It will probably have to go get repaired...
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-21-2008 11:25 PM
FE, "friction modifiers", and additives. DracoFelis General Fuel Topics 28 09-05-2006 09:37 AM
Congratulations Jared!!! SVOboy General Discussion (Off-Topic) 7 08-13-2006 08:55 PM
