Peakster's Scanguage is in! - Page 2 - Fuelly Forums
Old 12-13-2006, 04:17 AM   #11
Originally Posted by Peakster
Ok. Another question:
When my car is fully warmed up and it idling at a stop, my RPM reads around 750-800rpm which turns out to be a refreshing 0.1Gallons/Hour.
However, whenever the car is in motion, say 30mph, when I push in the clutch the car likes to idle around 1250 RPM instead which translates to 0.2Gallons/Hour.
Why doesn't the engine idle at the 750-800 range when the car is in motion? It would be nice to have that 0.1GPH while coasting. Is there a way to change the idle speed? Or is there a good reason why it idles at 1250RPM?
I think it something to do with manual trans. the computer thinks you might go back into gear while still moving.
Old 12-14-2006, 12:00 PM   #12
Peakster's Avatar
Wink Mph is like the big bully for Gph
Ok. So here's the preliminary fuel usage for my Geo via information of the SG:
Warm idle when stopped: 0.1gph (very rare sight. 0mpg nonetheless)
Warm idle while coasting: 0.2gph (usually well over 100mpg)
Very cold idle: 0.3gph
30mph in 4th gear or 35mph in 5th gear: 0.4gph (75-87mpg)
45mph in 5th gear: 0.7-0.8gph (56-64mpg)
50mph in 5th gear: 1.0gph (50mpg)
50mph uphill climbing in 5th gear with gas pinned: 1.8gph (28mpg)
So basically in simplest form, to improve FE I need to somehow decrease my gph consumption while still maintaining high mph.
The mph is like the overweight kid that can't move on it's own (unless it's downhill ) while the gph has to tote the heavy mph around. You can get good FE by getting the gph to bring mph up to speed and then giving gph a break... but slowly the annoying mph loses momentum and the gph has to go to work again.
gph: "Oh no! not another hill! For heaven's sake mph, lose some weight!"
Old 12-14-2006, 01:01 PM   #13
zpiloto's Avatar
Warm idle when stopped: 1gph (very rare sight. 0mpg nonetheless)
Warm idle while coasting: 2gph (usually well over 100mpg)
Very cold idle: 3gph
30mph in 4th gear or 35mph in 5th gear: 4gph (75-87mpg)
Did you forget the decimal point for the idles? Shouldn't it be .1 and .2 GPH?
Looks like you want to plan your routes to be somewhere around 30-40 MPH
Old 12-14-2006, 01:05 PM   #14
Peakster's Avatar
Whoops. You're completely correct. It's now edited.
Yes, that would be optimum. I'm now totally avoiding the freeway (unless it's at night where I can get away with driving 40mph). The only downside to the city driving is the stop and go. I'm not too sure if the 1 or 2 city blocks of CODFISHing in my car is enough to offset the horrible FE my car gets when accelerating from a stoplight. My city is completely flat, so Fas'ing isn't really ultra-effective anywhere.
Old 12-14-2006, 01:22 PM   #15
zpiloto's Avatar
Peakster. I was looking at your garage and you say that you have a EBH but don't use it. Why? It should make a pretty big difference especially where you are located.
Old 12-14-2006, 01:33 PM   #16
Peakster's Avatar
Peakster I was looking at your garage and you say that you have a EBH but don't use it. Why? It should make a pretty big difference especially where you are located.
I usually park in an insulated/heated garage when I get the chance. Right now, the Geo is parked on the street (didn't want to wake family with garage door), but there is a silly bylaw in Regina that states that no extension-cords can cross the sidewalk. Plus I've driven off WAY too many times with them still connected!
Old 12-14-2006, 01:36 PM   #17
zpiloto's Avatar
Ouch. Just cover it in the snow
City vs Highway Chart waterboysh Fuelly Web Support and Community News 2 03-07-2013 11:48 PM
Suggested improvement to distribution graphic cmumford Fuelly Web Support and Community News 4 03-20-2012 12:17 AM
Old school cylinder deactivation MetroMPG General Fuel Topics 11 06-09-2006 07:29 AM
WAI revisited. zpiloto General Fuel Topics 14 05-16-2006 04:08 PM
Water Fuel System diamondlarry General Fuel Topics 0 11-14-2005 01:20 PM
