Removing the water pump... yes? no? - Fuelly Forums
Old 07-05-2006, 03:58 PM   #1
Matt Timion's Avatar
I was reading this article:
http://www.evworld.com/view.cfm?sect...le&storyid=505
And I started thinking about the viability of removing the belt driven water pump and replacing it with an electronic water pump inline with the radiator hose.
How realistic do you guys thing it is? HOw easy would it be to do? How much MPG do you think we could expect to gain?
Old 07-05-2006, 03:59 PM   #2
But then what timing belt would you use?
Old 07-05-2006, 04:00 PM   #3
that wasn't the question.
Old 07-05-2006, 04:01 PM   #4
But if you removed the water pump your timing belt would be much to large, would it not? I'm sure you can install and inline pump, but I'd think you'd have to find a timing belt that would be the right about of tightness to work without the water pump in the way.
Old 07-05-2006, 04:07 PM   #5
two options:
1) leave the gear in place for the water pump, but remove the blades. The gear will still spin.
2) Remove the gear all together and get a bigger timing belt tensioner.
Old 07-05-2006, 04:09 PM   #6
I understand now, idiot ben.
Old 07-05-2006, 05:51 PM   #7
XFi
XFi's Avatar
Know anyone who has done this??? I would be up for it, any leads on an inline pump? Metros do not run the water pump off the timing belt (runs with same drive belt as the alt.)...I already have the alt. disconnected...if I did this, I could remove the belt and shed the weight from the alt.
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline   Reply With Quote
Old 07-05-2006, 06:00 PM   #8
Don't know anyone who has done this except the guy in the article.
All that you need to do is figure out a way for the pump to turn on at a certain temperature and you'll be good to go.
Old 07-05-2006, 06:20 PM   #9
Tuggin at the surly bonds
Silveredwings's Avatar
My passat has two water pumps: one driven by a serpentine belt off the crank pulley, and an auxiliary electric pump. I'm not sure why they do this or what the capacity of the electric pump is but it's for a 2.8L V6. It might have the capacity to keep a smaller displacement motor cooled.
Old 07-05-2006, 06:22 PM   #10
you will want to keep the water circulating all the time and circulate faster when you start overheating. It is important to be circulating the water in the head and block constantly to prevent hot spots from developing.
More detail josh434 General Fuel Topics 2 06-28-2009 02:39 AM
Fuel Economy and Lease Mileage RespecttheT Fuelly Web Support and Community News 2 08-14-2008 06:42 AM
San Jose Police overinflate tires to 50 PSI to improve performance and have realized significant cost savings..... krousdb General Fuel Topics 10 04-23-2006 04:15 PM
Crazy Spark Plugs Claim Increase of 50% in Gas Mileage SVOboy General Fuel Topics 13 12-29-2005 05:36 AM
