Winter is not Cool... - Page 2 - Fuelly Forums
Old 11-23-2010, 01:33 PM   #11
Re: Winter is not Cool...
If you have 10-30W oil, you should change to 5-30, or even to full synthetic if temp are real low, because they oil will stay liquid. Your start will be better and your engine will warm up faster.
AND the most effective thing still a block heater, cheap and easy to use with a timer because you need only 1 hour to get the oil warm (less cold....).
Old 11-24-2010, 08:39 AM   #12
I was just thinking the same thing (about winter sucking my mileage away from me... lol)
I actually just ordered an OEM Honda block heater for my car. Hoping that will help a bit with the frost (dont know how much it will do for a lot for thicker ice).
Any type of car cover will help with de-thawing but the car has to be dry before you put it on or you could have a car cover frozen to your car (I had a friend do this once... lol).
I too had thought about a space heater in the car, but could never get past the thought/worry about the car going up in flames if something happened.
ben98gs is offline   Reply With Quote
Old 11-24-2010, 09:26 AM   #13
Lean Burn Mode
pgfpro's Avatar
Thanks for everyone's input.
I need to do some grill block also. With a high today of only 7*F and low of -8*F it just isn't holding the engine temp. like it should.
Plus I'm losing so much heat in the drive train while driving I think the tranny fluid and rear diff. are just constantly like molasses.
Old 11-24-2010, 10:22 AM   #14
benfrogg's Avatar
I'm thinking about a wintertime WAI on my VX. It should decrease warm up times by some amount... My volvo wagon had a "pre-heat hose." The air filter box has two inlets, cold air from the fender and hot air off of the exhaust mani. It has a spring loaded flapper valve (controlled by a small thermostatic valve thingy) that kept intake temps around 105df all the time.
You (or I) wouldn't have to get a WAI too close, just in the general vicinity of the exhaust mani for warmer air.
Additionally, if you went to a full underbelly pan, you drive train/tranny etc would stay significantly warmer. Just a thought. If you wanted to get really radical you could find a way to re-route your exhaust or a coolant lines back to the drivetrain.
B
DFCO in a 1990 Honda Civic STD aalb1 General Fuel Topics 12 11-05-2008 01:29 PM
high mph then glide bfg9000d Experiments, Modifications and DIY 56 09-25-2007 05:29 PM
Stickers! where to look at? GasSavers_BIBI General Fuel Topics 2 08-03-2007 11:49 AM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
Intake Manifold Polishing Theory SVOboy General Fuel Topics 32 04-11-2006 08:44 AM
