Harbor Freight: Friend or Foe? - Fuelly Forums
View Poll Results: What % of Harbor Freight Items Have Been Defective for You?
80-100% 2 5.71%
60-80% 2 5.71%
40-60% 2 5.71%
20-40% 8 22.86%
0-20% 21 60.00%
Voters: 35. You may not vote on this poll
Old 03-28-2009, 09:10 AM   #1
I have had a problem with approximately 50% of everything I order from Harbor Freight Tools. This, combined with the end of their free shipping on orders over $50 has really cut down on my purchases from them. I just decided not to get a $99 pneumatic floor stapler from them because of past issues with their pneumatic equipment. In fact a pneumatic hose from them failed only a few days ago. I've requested they add user ratings for items on their site, but I seriously doubt they'd ever do so. They've been very good about returns (even paying return postage), but the hassle isn't usually worth it. If I lived close to one of their stores it'd be different, I suppose. Anyway, what percentage of Harbor Freight items have been defective (or just unacceptably low quality) for the rest of you?
co de pen den cy
Function: noun
Date: 1979
Old 03-28-2009, 10:16 AM   #2
Spent a little time remembering my failures with HFT items. Maybe we can spot some trends.
In no particular order:
venturi vacuum generator - internal fittings not sealed properly, fixed it myself
framing nailer - would drive multiple nails at a time - very dangerous!
wire feed welder - trigger failure - always on - really dangerous!
pneumatic hose - 250 psi rated, but failed at 100 psi - removed damaged part...we'll see if it fails again
cordless mini chainsaw - no power, short battery life, returned it
combination mill/drill/lathe - cheaply made
drill chuck for mill/drill/lathe - under moderate torque chuck came off - assume faulty shrink fit as there are no threads or other attachment device
router table - very poorly made
pocket hole jig - holes drilled at wrong angle, sent two replacements, also bad
pneumatic stapler/brad nailer - died shortly after warranty expired (my older one from them is still going strong after much use, but model discontinued)
4x8 trailer - lights & plug poor quality, trailer itself seems acceptable, however
cordless drill - short battery life. Others have reported success with these since so maybe a new model?
spot welder - no timing electronics of any sort, added them myself & works OK
1/2" router - terrible quality, bought for friend as a throw away for one specific job and it was, although it did get the job done
sander - internal electrical connections could not withstand vibration - fixed it myself - so cheap it was hard to be very upset
various very cheaply made hand tools - gifts from an uncle
one of those tubular steel, tarp covered car ports - first moderate winds mutilated it - they took it back at least
I have had success with quite a few things, however. Noticed a general trend where over time I've steadily been ordering fewer and fewer complicated or expensive items. Many fewer failures as a result. More money since college has helped with this decision.
co de pen den cy
Function: noun
Date: 1979
Old 03-28-2009, 12:12 PM   #3
Member
Ratman667's Avatar
I have only had one tool purchased from them fail.
I have an angle grinder I purchased back in 2005 and used daily for 2 years. Still works fine.
I bought an impact wrench, an air ratchet, and a few measuring tools two years ago. I donated the impact to my shop when I bought my snap-on, but it is still used heavily, daily. The air ratchet, I use almost daily and have had no problems with.
I bought some impact sockets and a venturi pump for air conditioners last year. The venturi pump, has been used twice, but worked excellent. The impact sockets, well i break one every once in a while. Thats to be expected with any brand, if you are hard on them.
The only thing that I had a problem with was a strut spring compressor. I used it and got the job done, but they broke as i was finishing up the last strut. I just returned it.
All in all, I have not had any major problems with them. Just keep that old adage in mind: you get what you pay for.
Ratman667 is offline   Reply With Quote
Old 03-28-2009, 12:43 PM   #4
Makes me think of another one:
It's almost always possible to make something a little cheaper by making it a little worse.
I guess the practical impact is that for important items, you shouldn't go with the lowest priced item, at least without proper research or reviews.
co de pen den cy
Function: noun
Date: 1979
Old 03-28-2009, 01:05 PM   #5
I usually buy small items, not a lot of power tools or big-ticket stuff, from Harbor Freight. I've got a few. Most of what I've bought has worked out great. I've had a couple small failures; the one I can remember at the moment was a butane torch that fell apart. They replaced it.
I'm lucky enough to have a HF store about 25 miles from me. It's not far off the route to my parents' place, and there's other places nearby that I sometimes need to go, like Pep Boys, which is the only place with the oil I buy for the VW. In fact, tomorrow or next weekend I'm going to Pep Boys, I wish I had some extra dough to blow at HF.
Old 03-28-2009, 01:13 PM   #6
depends, our angle grinder is used and abused yet still fine. weve bought countless wrenches, sockets, pliers, etc from them all have lasted.
we have a jack from them that works just fine. we havent really bought big machine stuff from them but all the simple stuff works just fine.
Old 03-28-2009, 01:14 PM   #7
They keep sending me 20% off coupons that are only good at their stores! Some sort of cruel joke, no doubt.
co de pen den cy
Function: noun
Date: 1979
Old 03-28-2009, 02:21 PM   #8
My dad buys stuff from them, but I think their main problem is that they sell cheap Chinese tools. If I need a tool for one job I'll buy from them, but if its a tool that I need to use over & over I'll buy better quality.
Old 03-28-2009, 04:38 PM   #9
yup, get what you pay for. the same could be said of big lots.
i buy hammers, hand saws, etc from them, but i'd stay away from drills, power saws and such.
recently bought a rubber mallet(multi-tasker) for 99 cents that serves mostly as a wheel chock.
that reminds me, gotta make a trip to big lots, tractor supply, the dollar tree, and home depot tomorrow(all w/in a square mile). oh, and advance auto.
Old 03-28-2009, 04:43 PM   #10
Lately for one job I'll buy the tool from ebay (used), then sell it again when I'm done. Winds up not costing too much and I can get something that's got actual reviews. Not to mention two more points on my ebay rating!
co de pen den cy
Function: noun
Date: 1979
I have got a new bike :) landspeed Motorcycles 12 11-22-2008 04:04 AM
been researching several possible mods,but.... goofy1 Experiments, Modifications and DIY 11 06-12-2008 05:21 PM
Muffler question? coastertoasterxb General Fuel Topics 5 08-02-2007 06:10 PM
AC in VX McPatrick General Maintenance and Repair 14 06-27-2007 01:04 PM
Possible VX problem.. GasSavers_NickF829 General Maintenance and Repair 52 06-11-2007 06:24 PM
