Ram Air Wind Alternator - Page 3 - Fuelly Forums
Old 11-01-2006, 04:16 AM   #21
For anyone bound and determined to capture some wind energy, I'd suggest getting one of those boat windgen units and coming up with some sort of telescoping pole and folding blades so you can unfurl it when you park and capture wind energy WHILE THE VEHICLE IS PARKED.
Like this:
http://solarvan.co.uk/wind.htm
Old 11-01-2006, 05:50 AM   #22
Team OPEC Busters!
GasSavers_Brock's Avatar
Looks like an Air 403 to me.
Old 11-01-2006, 05:53 AM   #23
Its just like this but runs on solar...
Old 11-01-2006, 05:55 AM   #24
Too funny. There are some short videos on the solarvan site (last time I looked) which show him setting up the mast & generator, etc.
Old 11-01-2006, 06:11 AM   #25
That looks like the one on my buddy's boat that I saw putting out 20 amps into the 12 volt batteries in a 29mph wind and his blades looks about the same size - supposed to be a 600 watt wind generator on his boat.
Old 11-01-2006, 02:17 PM   #26
omgwtfbyobbq's Avatar
Originally Posted by MetroMPG
Can you point to a source for that info? Wikipedia (all of which is true, btw) claims 90% alternator efficiency:
http://en.wikipedia.org/wiki/Alterna...harging_system
From that same page
Originally Posted by Wikipedia
In comparison, the best permanent magnet generators, such as those used for bicycle lighting systems, achieve an efficiency of around only 60%.
In terms of alternator efficiency, the conversion of mechanical to electrical may be very efficient, but it still goes into charging a battery which loses some efficiency, the laternator may only reach peak efficiency at a certain engine speed, so overall efficiency may be mucn lower than peak efficiency, etc... The alt efficiency clip was based off this blurb on diesel alternators. I'm guessing normal auto alts are the same or worse in terms of efficiency. 100% pure truth.
Old 11-03-2006, 09:15 AM   #27
Send a message via ICQ to BuffaloChips Send a message via AIM to BuffaloChips Send a message via MSN to BuffaloChips Send a message via Yahoo to BuffaloChips
I haven't read all the responses here at the moment. But, to JanGeo, The idea of a clutching system was to alleviate the horsepower drain not stop the engine alt. from producing power. As for increasing the ram air system discussed. Have you thought about, or tried some type of funneling device to catch more air and accelerate it into a smaller more compressed area? I doubt the issue of extra drag from a system like this would truly be significant. I know a guy that drives his truck everywhere with the hood popped to the safety latch. This lets the hood sit up at least an inch. He claims he gets about a 3mpg boost on the highway just doing that. He hauls granite loads a lot and doesn't seem to thing there is significant drag.
BuffaloChips is offline   Reply With Quote
Old 11-08-2006, 07:28 AM   #28
before everyone here tells you not to do it.
just go freaking do it.
then tell us how it works out!
but seriously tho, only charging while moving etc....
the ram air will mess up your aerodynamics....
run it like this.... Put it in your back bumper, with a hole cutt for the fan, whatever u use to spin. make a scoop to it. THEN, have it so that it will capture the exhaust gas blowing onto it, as well as, the air you are generating while the car is moving.
Hmmm.... Isn't this called a turbo turbine???
Old 11-08-2006, 07:34 AM   #29
Originally Posted by ketel0ne
So here's the concept a, 6-8" Ram air tube from the grill to an 6-8" blade assembly with a larger pulley to a half sized pully on one of these alternators. I have several hundred pages of alternator documentation(zip file) of how to pull this off. Looking for your thoughts. Also thinking that a solar panel could be rigged into the setup as well against the battery.
http://cgi.ebay.com/Permanent-Magnet...QQcmdZViewItem
Interesting! Have you considered the power req'ts of spinning this alternetor assembly at some (lower?) RPM? Nothing is free...not even power-making devices; ie, it takes power to make (less) power! The law of conservation of energy prevails....And, have you considered the square footage involved with the solar collector...just to generate the current required to charge / partially charge the battery while "motoring" down the road? Wow! If it were feasible, the aftermarket would have scooped this up !
Old 09-06-2008, 02:03 PM   #30
FX Flyboy's Avatar
Originally Posted by Matt Timion View Post
It would work wonderfully at highway speeds IMHO, but what about city driving?
I still think that finding a way to do this with the exhaust gases would be the best bet. If you could rig it up to capture both exhaust and wind that would be the best.
KetelOne, I have to agree with Matt here. I've only started on this forum, so don't take my word for it, but here's the logic:
Alternator belt on the engine driveshaft produces drag on the engine, and your idea will simply move that drag to the aerodynamics side of things.
However, the combined heat and kinetic energy of exhaust gases is higher than that on the wheels of your car (SIC!). Therefore combining a modified turbocharger and alternator/powersteering/AC/etc. would logically make more sense.
Here is where I got the inspiration from:
YouTube vid explaining the energy in exhaust gasses
Then I googled "connect turbine to an alternator" and one of the first results is this patent website:
EXHAUST-DRIVEN TURBINE-POWERED ALTERNATOR
After I saw this I started a search on here and found your thread.
Might save a few HP and not produce ANY additional drag. What do you think? I'd be interested to see this.
I've also started looking at ebay listings for turbocharges that I could get cheaply and start modifying.
FX Flyboy is offline   Reply With Quote
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 10:26 AM
Best Diesel in N. Texas? JudisJetta General Fuel Topics 7 05-28-2010 08:55 AM
