skirts - Page 2 - Fuelly Forums
Old 05-02-2006, 02:00 PM   #11
Eww, that's so weird. I
fuel economy forum
vegan recipes
green home improvement
honda gas mileage
Old 05-02-2006, 02:03 PM   #12
Compaq888's Avatar
also on high speed cornering
also on high speed cornering my rear wheels develop more toe in to stabilize the rear end. Never in the lifetime of owning the vehicle has the back ever slipped, even with ****ty tire. I did have some understeer when I made a high speed u-turn. On my cousin civic I turned really fast and the back slid out HAHAHAHA
Old 05-02-2006, 02:31 PM   #13
Re: also on high speed cornering
My old Civic was setup for autocross and did the same thing -- it was fun.
But yes, I had probably about 400-lbs. of bricks in the back of the Integra, and it had a nice, lowered look when parked (only in the back of-course). We never hit the bump-stops during the ride so, it was all good (who needs an SUV when you have a hatchback???)
Imagine a wheel pivoting on the suspension attachment point -- when it goes up, the 12-o'clock position tilts in while the 6-o'clock tilts out. You can really see it on the front of old worn-out Ford Tempos. The suspension sags in the back while the front wheels tilt outward due to the extension of the suspension. Watching them go over a bump shows the whole indpendent suspension process in excess (except the rear -- not indep.) -- the front wheels will tilt in and out over an undulation while the suspension goes down and up, respectively. Old, poorly maintained 300Z's have this problem in the rear as they sag over time as well.
(KCØWPM)
Old 05-02-2006, 02:31 PM   #14
Quote:How is your progress
How is your progress on the grill block??
haven't started. well, not true. i put some fresh tape on to keep the cardboard from falling off completely. i may go have a look at the grille block issue this evening.
Have you had any problem with suspension travel (camber) and the flare location?
no - but i haven't really checked it. there's about a 1.5 inch gap between the skirt and the wheel, so i'm thinking it'll be okay. plus the flare is out, not in, so there's actually slightly more space at the very bottom of the skirt. though it's hard to tell from that pic.
Old 05-03-2006, 12:19 AM   #15
philmcneal's Avatar
wow didn't know you can
wow didn't know you can cover up the front wheels too and expect the reduce drag to have an affect there. By the way does water evenually unsticky the velco?
the only disadvantage i see with wheel skirts (besides the look) is that the fact if your trying to check pressure and the air nozzle is hidden, then that will be indeed a pain.
Old 05-03-2006, 02:33 AM   #16
Compaq888's Avatar
push the car forward or back
push the car forward or back to get to the nozzle. When I don't want to start my car I just move it forward or back.
Old 05-03-2006, 05:04 AM   #17
Re: wow didn't know you can
phil, check the pics in this thread:
http://www.gassavers.org/forum_topic/aerodynamics_performance_and_economy.html
no - it's a mechanical connection between the two halves, and the adhesive holding the velcro to the car & skirt is waterproof.
as i mentioned though, i'd be careful with a pressure washer. directed high pressure water might peel the glue.
you know, i have slowly come to like the look. since the plastic skirts turned out nicely, i *really* like the look. though wheel skirts are probably the pocket protector equivalent in automotive fashion.
compaq's right - just roll the car to get to the valve. (or clean the wheel, whatever). it's just one more thing that's slightly more work to get slightly better mpg.
Old 05-03-2006, 11:19 AM   #18
Noticed something else
I noticed something else in your skirt pic. Have you altered the spaces in the wheels themselves? It looks like black inserts in the gaps with a hole for the valve stem. Is that stock, and if not, has it helped?
It would be a next to impossible for my 30-something-spoke wheels (and I'm sure covers to go over the entire wheel aren't made -- plus the concern that it would have an adverse effect on brake cooling).
Old 05-03-2006, 11:39 AM   #19
Matt Timion's Avatar
Re: Noticed something else
From what I've read brake cooling is only an issue if you're braking a LOT... and by "a lot" i mean going down mountains on a regular basis. People here in Utah use their brakes going down mountains and don't konw why their cars catch on fire.
I think for the most part brake cooling isn't even to be factored in.
Old 05-03-2006, 12:18 PM   #20
Compaq888's Avatar
you can buy dish hubcaps
you can buy dish hubcaps that are completly covering your rim. They are exactly the same ones on that aerodynamic truck.
Hello GasSavers GasSavers_rGS Introduce Yourself - New member Welcome 1 06-10-2007 07:47 PM
Finally made it! GasSavers_TomO Introduce Yourself - New member Welcome 13 11-13-2006 09:00 AM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 07:40 PM
