Tail pipe restrictor test - Fuelly Forums
Old 11-11-2007, 04:18 PM   #1
GasSavers_Erik's Avatar
I read the high flow muffler thread and was motivated to start a test last weekend.
I filled my 87 Civic's tank and then I drove a little more than 200 miles this week with a crude mod that decreased the size of the tailpipe opening from 1.5 inches to about the size of a dime. Its actually a steel can that is clamped over the tailpipe with a radiator hose clamp (fuzzy pic is attached).
Mileage for this tank (with the restrictor mod) was 37.45. The last tank was 38.59 mpg.
The A-B B-A part of the test I drove was 120 miles (60 miles between A and B) at 60 mph. The other 80 miles or so were mixed city/highway driving.
The weather was colder this week than last week and I wasn't sure if the previous tank was completely full. I also did no EOC this tank.
Noise- about the same at idle, definitely quieter at 60 mph.
Driveablility- not noticeable around town, a little less power on long steep hills
Other differences- when pulling a long steep hill, I could see the engine temp coming up noticeably even when outside temps were cold. It usually stays within 1/3 and 1/2, on a few hills it went up to maybe 60%. The temp doesn't rise this much without the mod when driving the same hills in warmer weather.
(By the way, I know I was no where close to boiling over. I overheated the engine several months ago and recall that it happens at the edge of the red zone- or at about 95% up the gauge).
I could also tell that the cooling fan was running more even when in city traffic. This makes sense because probably more of the hot exhaust gasses were remaining in the engine.
I plan to test it for a few more tanks before making a judgment. Right now I feel the results are inconclusive as to whether it increased or decreased my mpg.
The next model I build to test this will be a spring loaded exhaust tip that will maintain a certain amount of backpressure regardless of engine load/rpm.
I'll probably take it off tomorrow and do a few tanks without it and then do the improved version.
Old 11-11-2007, 04:25 PM   #2
A better pic
But not much better
Old 11-11-2007, 04:35 PM   #3
Good idea- I was hoping that would be a beneficial "side effect" of my restrictor but i couldn't tell that the warm up time was any shorter.
Unfortunately, it takes this engine a long time to warm up because of the huge intake manifold that has coolant circulating through it.
Old 11-11-2007, 04:38 PM   #4
cfg83's Avatar
theclencher -
that's cool
i wonder if warm-up times could be enhanced with a tailpipe throttle?
also exhaust throttle shut when p&G?
should put em on priussesss
That's what I was gonna say! This is a very easy mod to test.
Erik -
Interesting observations. I like that you are maintaining driveability. Since your engine is running hotter, I wonder if this could be another "winter mod" in the making?
Old 11-11-2007, 04:44 PM   #5
CoyoteX's Avatar
Is your exhaust stock or has it been modified?
There might already be enough restriction in a stock exhaust so adding more might not help much.
Old 11-11-2007, 04:45 PM   #6
Rick Rae's Avatar
Whoa, what a nifty concept!
This one deserves playing with. Could make a nice complement to grille blocks and so on.
Figuring out how to add a "choke" or whatever you'd use to adjust it might be interesting, though.
"Tailpipe Throttle" -- I like that!
Rick
Rick Rae is offline   Reply With Quote
Old 11-11-2007, 04:49 PM   #7
CoyoteX's Avatar
http://www.jegs.com/webapp/wcs/store...1_46544?CT=999
How about that and just swap out springs on it to adjust the pressure
Old 11-11-2007, 05:44 PM   #8
Very good idea there- I was about to fabricate something, but that will be the easy route.
I wasn't doing this as a warm up strategy (although that could be a benefit), I was more interested in it as a "forced EGR" device. I was hoping that more backpressure would cause more exhaust to remain in the cylinders so less air/fuel was drawn in. This would cause one to open the throttle more, which should reduce cruising vacuum losses.
BUT, on the negative side, it will increase pumping losses on the exhaust stroke and when I open the carb throttle plate more, the power valve may be opened so that my mixture gets richer- which would be bad news for FE...
Old 11-11-2007, 05:47 PM   #9
I have a stock muffler and tight exhaust pipes, but the cat. converter and resonator are missing .
Old 11-12-2007, 07:58 PM   #10
I'll make it simple:
An Ice requires three things:
Air
Fuel
Spark
Increasing Air and / or spark should increase mpg so long you do NOT 'test' your new found power. Increasing fuel otoh will not increase your mpg.
As for the air, it really doesn't matter whether you increase the in or the out flow, for best results enhance both.
Too many entries W/ "0 MPG" DPTyphoon Fuelly Web Support and Community News 7 09-13-2008 02:19 AM
Save $$$ on Wood Carving you didn't buy. CO ZX2 General Discussion (Off-Topic) 5 06-03-2007 11:56 AM
WTB 5 wire O2 Sensor GasSavers_Jack For Sale 6 12-01-2006 01:00 AM
Greetings kps Introduce Yourself - New member Welcome 10 09-26-2006 05:15 PM
Ok, you Screw Balls! kozaz General Discussion (Off-Topic) 10 08-23-2006 06:06 PM
