Signature showing wrong MPG
For some reason my stats on the front page are showing 55.9mpg, which is correct and this is the same on the graphics, but my signature that's linked and on the site is showing 72.9mpg. Anybody know what's causing this?
Did you just update your log very recently? It can take a little bit of time to update.
https://www.fuelly.com/faq/24/Fuelly-...ignature-cache Why is my Fuelly forum signature/badge out of date? We serve thousands of forum signature images each day and to keep them (and this site) speedy we write the images to a cache. That means there could be a lag between adding a fuel-up, and having that fuel-up reflected in your Fuelly signature. Badges are updated each time you add, edit, or remove a fuel-up. If your badge isn't reflecting your most recent fuel-up you could try editing an existing fuel-up to reset it. You might also be seeing a locally cached version of the image—some browsers and networks are more agressive about caching than others. To check, try bypassing your local cache with a hard refresh. In many browsers, reloading the page where you see the image with the keys Ctrl + Shift + R will do it. For specific instructions for your browser, look at these instructions at Wikipedia. |
Updated it, but the MPG on the signature is impossible and unrelated to any figures I've got.
The average on my stats front page is correct at 55.9mmpg. |
Was this mileage log entry correct?
01/06/11 1,318.0 20.75 1.359 50% 1318 miles on 20 litres is bound to cause your average figure to be messed up... |
Also, the entry on the 6th June also looks odd. Exactly 500 miles?
06/06/11 500.0 20.43 1.359 50% That'll also give you a very high MPG figure. |
MMUK - thanks, it's obvious when somebody else is looking!
