$79 5 wire O2 sensor - who has bought one? - Page 3 - Fuelly Forums
Old 10-20-2007, 05:36 PM   #21
garyhgaryh's Avatar
Originally Posted by 1993CivicVX View Post
that would be the new $79 one I bought.
But good point, I will compare it to the old one.
And that is the one you bought at Global automotive right? If that # is
engraved into the O2 sensor, then I'm going to get it.
I heard the Bosch 13246 also is NTK with the Honda part # either engraved in it or
stamped somewhere..
This is really good news 1993CivicVX! Can you take a picture of it and upload it
here?
Gary
garyhgaryh is offline   Reply With Quote
Old 10-21-2007, 12:10 AM   #22
I just bought the one on ebay from "GLOBAL-AUTOMOTIVE" titled "NEW NTK OEM OXYGEN SENSOR 5 WIRE 1992-2000 HONDA CIVIC". I just installed it on yesterday. When I got it I noticed the wires looked a little short and the "honda part# sticker" looked a little out of place. Sure enough the wires were way shorter than the ones on my stock sensor. I accidently pulled some of the wires out of the harness plug when I tried to plug it in. I ended up cutting the harness off of my old sensor and joing it with the new sensor to lengthen it. I got it all together and started my car to find that it worked just fine. I drove a few errands in town and then took off for the beach for a 125 mile test run. So far no problems and my car runs way smoother. I don't know what the whole sticker thing is about (instead of stamped or ingraved!?) but the sensor seems to work fine. $79+6 shipping isn't too bad...
c3474i is offline   Reply With Quote
Old 10-21-2007, 06:57 AM   #23
1993CivicVX's Avatar
the number isn't engraved, only the "Honda NTK" I will post pics shortly.
three stripes the charm!
Old 10-21-2007, 07:05 AM   #24
for the thing working, that's hella cheap!
Old 10-21-2007, 11:05 AM   #25
Couldn't get the nut loose with an adjustable wrench and no way of getting box wrench on it without cutting the wires so I am going to have the mechanic swap it out. Shouldn't take him more than 10 minutes, right? It was $40 for an o2 sensor socket wrench. Mechanic should be able to do it for cheaper.
I soaked and resoaked the nut in PB Blaster (over night). No dice.
Old 10-21-2007, 11:12 AM   #26
You lie on the cost! You lie...
http://www.autozone.com/R,NONAPP2327...ductDetail.htm
You should be able to get just the socket for like 8.99 or sommick. Screw the mechanic and use your saved money to buy tools,
Old 10-21-2007, 11:22 AM   #27
will i have other uses for that socket? Seems like it's designed only for the o2 sensor removal and installation.
Old 10-21-2007, 11:23 AM   #28
garyhgaryh's Avatar
Great find!
Or you can get one of these:
http://www.harborfreight.com/cpi/cta...emnumber=95045
That's my favorite store. I spend close to $100 everytime I go there .
Gary
Old 10-21-2007, 11:26 AM   #29
It is indeed only for that...but think how nice it is to do it yourself and how helpful you'll be when I friend needs it...
Old 10-21-2007, 11:31 AM   #30
hmm.. sorry, not a very good picture. but you can see the K that is from the NTK. And the number is on that sticker.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Synthetic Bad for the TSX rh77 General Fuel Topics 41 11-30-2006 12:02 PM
Hello GasSavers_scostanz Introduce Yourself - New member Welcome 7 06-25-2006 07:37 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
