Any Honda owners with an Engine Block Heaters? - Fuelly Forums
Old 12-03-2006, 07:28 PM   #1
If there is anybody out there with a honda, who put in an EBH, lemme know. I don't know which kind to get or where the best place on the head is to stick it. I really want one I can just plop on the outside of the head without drilling or anything. I am lazy.
I have a 91 civic hatch that I have recently modded for the winter (i.e. wai, grill block, 195f thermostat, m1 0w20) and want that last important mod besides a belly panto really make up for the cold, an engine block heater.
budomove is offline   Reply With Quote
Old 12-03-2006, 07:29 PM   #2
An engine block heater(S)?
Old 12-03-2006, 08:18 PM   #3
GasSavers_Ryland's Avatar
most engine heaters are oil pan heaters, aren't they? either that or a coolent heater, I would think that warm oil would do the most good as it would flow, and warm up the rest of the engine fastest (a gallon of hot oil should be able to hold alot of heat, right?) so it seems like a vaugly universal type heater should work fine, or you can alwas ask the honda dealer what they install.
Old 12-03-2006, 08:57 PM   #4
Yeah, I'm gonna ask the dealer tomorrow, and let ya'll know what they say.
Old 12-04-2006, 04:04 AM   #5
Moderator
GasSavers_DaX's Avatar
Keep me posted...I may want to do this too.
Old 12-04-2006, 04:29 AM   #6
zpiloto's Avatar
Metro has a great article on his sitehttp://www.metrompg.com/posts/block-heater.htm
everything you wanted to know.
Old 12-04-2006, 07:17 AM   #7
just asked honda parts, and they say there is an external bolt on that they use on their new cars. The one that I would need on a 91 has been discontinued. He said the new cars have a bolt on the head that is removed and replaced with the external EBH. He did not know whether my 91 would have this bolt hole or where on the block it might be, as he didn't even know where on the block they currently have the bolt. I will look on my block and see if I can find a bolt somewhere.
Old 12-04-2006, 07:28 AM   #8
If you have the choice, the frost-plug type is the best commonly available heater, and a good price/effectiveness combo. I'd go that route if you can.
Old 12-04-2006, 08:05 AM   #9
Metro, I'd love to go that route, but my skills are limited, and don't you have to remove the head and put the heater inside the block? just found this magnetic, but you said these are pretty inefficient, huh? Are they any less eficient than the external bolt on, you think?
magnetic:
http://www.jcwhitney.com/autoparts/P...c-10101#review
edit: Your oem 300w external is a lot sweeter than the oem honda 15w. went on a hch site where these guys are talking about plugging in for 8 hours. no thanks! and they all paid $135 for that. 60 for part, and another 75 for the dealer to screw the thing in, and run a couple zip ties.
just realized the magnetic prolly won't work on hondas, cuz don't we have aluminum blocks? hahaha
Old 12-04-2006, 08:23 AM   #10
Nope. You drain the coolant, remove a frost plug from the outside of the head or block, install the heater in place of the plug, refill coolant.
If you can't do that, be our guinea pig and install a recirculating heater hose unit. Brock, I believe, has a 1000 watt unit on his VW.
Broken Odometer PReta General Fuel Topics 6 12-15-2009 04:18 AM
126 mpg! Draigflag General Fuel Topics 4 08-20-2009 09:10 PM
Import/Export feature jimt Fuelly Web Support and Community News 2 01-09-2009 02:31 AM
More Fuel Saving Tip Suggestions jklaiber General Fuel Topics 1 08-11-2008 10:03 AM
