Carbon fouled O2 Sensor:'92 VX - Perplexed - Fuelly Forums
Old 03-09-2008, 11:41 AM   #2
Possible cause: Pinhole leak in one of the exhaust passages in cylinderhead, remove exhaust manifold and see if one port has been super cleaned as if it was steam cleaned which is what a pinhole leak does. Low pressure zone created in exhaust manifold at port syphons coolant out of the high pressure 13-16 psi in the water jacket. The only fix for this is to weld up the hole or replace the head. I would suspect that the previous owner had this problem, ergo the replaced head gasket. Good luck.
soletek is offline   Reply With Quote
Mercedes-Benz B 200 Mike T Car Reviews 18 07-25-2008 09:37 PM
200 MPG Santa Fe 2TonJellyBean General Fuel Topics 2 10-05-2007 07:16 PM
Any tips for ignition cut-off switch? slimreynolds General Fuel Topics 3 09-03-2007 08:01 AM
