Originally Posted by Darkelf
Ugh. Sounds serious. If this is the problem, is it possible to do a spot weld without pulling the head? Seems like access for someone to weld it should be decent with the head in place with the EM removed.
Maybe drive it to a weld shop, pull the exhaust manifold and spot weld? Or...?
It depends on how close to the exhaust manifold mounting surface the hole that [U]may[U] exist would be. If there is a hole, it would have to be TIG welded, a MIG (even with an aluminum spool gun) would not be capable of getting the penetration required. Also, if it is welded in the car, disconnect your ECU to protect it.
