Fuel Injection Lean? - Fuelly Forums
Old 01-17-2009, 02:22 PM   #1
check engine light came on today. SCII says P0171. Haynes manual says fuel injection system lean.
any thoughts?
2000 toyota corolla, i mean, chevy prizm 5 speed.
thanks.
Old 01-17-2009, 03:00 PM   #2
GasSavers_BEEF's Avatar
this may be a start
http://www.obd-codes.com/p0171
maybe it will give you some ideas
Old 01-18-2009, 05:53 AM   #3
thanks Beef!
from what i can ascertain from your link:
clean the MAF sensor and check for vacuum leaks downstream. and the sensor may need to be replaced.
Old 01-18-2009, 05:54 AM   #4
Site Team
Fuel pressure?
Dead injector?
Have you ever cleaned your injectors?
Wiring to an injector?
Lousy O2 sensor?
Lazy fuel pump? Low voltage to fuel pump?
Leak in the exhaust system?
Old 01-18-2009, 09:32 AM   #5
Bob,
everything is running great. mpg is a bit low, but it has been cooler on morning trips. scangauge shows good mpg during the day when temps rise(typical florida winter can be 40F am and 70F at noon). ~37 mpg am and ~43 pm to be specific.
i use amsoil fuel cleaner regularly, but the O2s are new and not OEM.
a toyota tech on another site says a dirty MAF(or one that needs replacing) shows no sign in regard to performance. sounds like my situation.
i did clean it today(MAF), and will add amsoil PI to the next fill-up.
Old 01-18-2009, 08:02 PM   #6
kamesama980's Avatar
be wary of any additives. an even marginally decent running car shouldn't need anything put in the oil or gas. additives can lead to bad readings and cars can be addicted to them (so to speak)
careful what you use to clean the MAF, anything not specifically made for that job can destroy the MAF
-Russell
Old 01-19-2009, 12:34 PM   #7
kamesama980,
there's a multi-award winning mechanic here locally that recommends fuel additives, BUT only certain ones. amsoil is one.
and i did use MAF specific cleaner that smelled suspiciously like brake cleaner. i wonder if i could have saved a few bucks going that avenue instead?
Old 01-19-2009, 03:24 PM   #8
Brake fluid? I can imagine them smelling like brake cleaner, because non-chlorinated "ABS sensor safe" brake cleaner is safe on them as is any "electrical contact cleaner" as is isopropyl alcohol.
Old 01-19-2009, 03:27 PM   #9
yup, brake cleaner, not fluid, thanks. it's been edited.
Old 02-27-2009, 02:49 PM   #10
i've cleaned the MAF sensor twice, and the FI lean code has come back twice. after resetting the code, it takes between half and 1/4 tank to come back.
looks like i'll be headed to NAPA soon.
would any like to speculate if this could lower FE? again, i've been a bit low, but each of the recent tanks have had some near freezing mornings.
94 GS-R with VX swap onefastcar Introduce Yourself - New member Welcome 9 07-09-2008 03:12 PM
