Possible VX problem.. - Page 3 - Fuelly Forums
Old 12-28-2006, 08:25 PM   #21
Matt Timion's Avatar
Originally Posted by SVOboy
Use www.honda-tech.com to find a pinout for the p07 (your ecu) and find the signal wire for the 02. Then tap that for the DVM.
krousdb told me which pins to attach the DMM to in order to test the Civic VX. It's in a post here somewhere...
Old 12-28-2006, 08:27 PM   #22
GasSavers_Ryland's Avatar
a Haynes manual will proove to be invaulable for all sorts of truble shooting and testing, and what that book does not cover, the factory shop manual covers, o2 sensor testing is better covered in the Haynes manual.
At some point I should have my copy of the factory shop manual edited in to chaptors, and posted for everyone to look at, as it is, it's a 35minute down load with a fast connection.
and I tried scaning in a page from my haynes manual, and couldn't get it to work, then I realised that as an owner of a car that the younger people at the dealer are going to tell you they "don't work on anything that old" (ask for the old crusty guy) you really need to spend $20 on your very own copy of a haynes manual.
Old 12-28-2006, 10:04 PM   #23
GasSavers_TomO's Avatar
Originally Posted by NickF829
the PCV i pulled out was blue and looked to be replaced somewhat recently. should i goto honda and get a different one?
You don't really need to. I didn't notice any drop in FE having a regular PCV valve in mine after I swapped it.
Honda Civic VX Info/Links
Old 12-29-2006, 04:10 AM   #24
Moderator
GasSavers_DaX's Avatar
I do 1/3 can of seafoam in the crank case, 1/3 can in a very low tank of gas, and 1/3 can sucked up through the brake booster, then drive hard and change the oil in a few days.
Old 12-29-2006, 12:51 PM   #25
XFi
XFi's Avatar
Originally Posted by MetroMPG
I wondered that too. I remember Dan (krousdb) describing it kicking in, and if I'm not mistaken, he described it as a noticable loss of power, and that he had to respond by pushing the accelerator more to maintain speed.
The VX does the same thing to me. Very noticable sometimes too. May be hunting down a problem that isn't there, just characteristic of the vehicle. Lean Burn Lag
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline   Reply With Quote
Old 12-29-2006, 01:44 PM   #26
Well, there is a certain amount of lean burn lag. That would best be determined by hooking up the DVM to watch the O2. But I know for sure that having the colder spark plugs in the VX causes more power lose than just lean-burn lag alone.
Old 12-29-2006, 03:15 PM   #27
GasSavers_Jack's Avatar
Ok add me to the list too. Mine does the exact same thing. Now that I hear everyone else's is doing the same think I am begining to think it is normal. Some where on here I have listed everything I have done to fix it all to no avail it still does it.
Just a side note I think that seafoam kills iffy o2 sensors. It killed mine and I saw on Honda Tech a few others that had the same thing happen. I have my old one to put back in if I even want to seafoam it again just in case.
Good luck with it. If you figure it out please let us all know.
See my car here:
Old 12-30-2006, 04:27 AM   #28
krousdb's Avatar
As other have stated in this thread, it sounds like lean burn kicking in and out. YOu should be able to hold lean burn up to 75 MPH. If you are driving faster than that, the activity you are explaining would be normal. In that case, it will go away of you slow down.
Old 12-30-2006, 05:38 AM   #29
so what causes the lean burn to kick in? because it will do it at speeds as low as 20mph upto 70(i dont drive faster then that). It just seems as if it does it when im just cruising down a flat road, it certainly is much better then before now that ive tuned it up but it still feels unnatural, at least for now.
GasSavers_NickF829 is offline   Reply With Quote
Old 12-30-2006, 06:02 AM   #30
I'm sure someone can chime in with a better response than me. In my VX I notice the Lean burn happening at a steady speed (for me anywhere between 55-65MPH) and after I've maintained that speed for at least 30 seconds. LBL (lean-burn lag {hmm, maybe a new acronym to add to the glossary?}) can still be felt by the driver of a VX and maybe a passenger if they pay attention enough. It usually takes about 3/4 of a second for it to disappear once you press the accelerator down.
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
Vortex Generators / Hmmm Airtabs zpiloto Experiments, Modifications and DIY 92 02-09-2007 07:26 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
possible switch to vbulletin tomorrow Matt Timion Fuelly Web Support and Community News 4 05-17-2006 10:31 PM
