Preventing crummy brake rotors when parked outside? - Page 3 - Fuelly Forums
Old 11-01-2007, 07:38 PM   #21
Rstb88's Avatar
Aluminum (either clad or throughout) seems rather expensive as does stainless steel. Its not a garage baby where you could put a dehumidifier next to it in the garage to reduce the inevitable humidity. The only cheap and somewhat time consuming would be to wrap the wheels up individually and find a way to create a vacuum or as close to one as you can to reduce the rust. Seeing as the diminutive size of the wheels it wouldn't be too complicated to cover them, but reducing the air you could use a small vacuum, and seal with duct tape.
It just came to me about blogging lol. Its like an orgasm a few good shots and the rest is dribbles lol!
Rstb88 is offline   Reply With Quote
Old 11-01-2007, 07:46 PM   #22
If I were, say, leaving the car parked for a known extended period - like while I sail the Caribbean for the winter (I wish!!) - I might consider doing something more drastic to keep the rust away...
But I'm not. Arrr.
Old 11-01-2007, 08:22 PM   #23
CoyoteX's Avatar
I would just ignore the noise and stuff. It isn't actually hurting anything and other than being annoying is not really that big of a deal.
You could oil the brakes down if you know it is going to be parked for a while. The pads will eventually become oil soaked if you do it often and will need to get hot enough to burn all the oil out of them either by driving like a nut or hitting the pads with a propane torch
Then again as little as you use the car you might want to oil soak the pads anyway, it will reduce rolling resistance and you don't hit them hard enough to worry about needing real strong brakes most of the time.
Old 11-01-2007, 08:31 PM   #24
Danronian's Avatar
But I'm not. Arrr.
Na. The best thing to do would be to sand off the rust when you get back, before driving the car.
Old 11-01-2007, 09:08 PM   #25
DRW
How about simply roll the car back by several cm to move the rust spots around every few days? A car like that should be easy to push, and you only have to move it by 1/2 turn of the wheels.
Or you could get a car cover and stick a dehumidifyer under it, but that would run off the grid and consume energy. OK how about a dehumidifyer running from a timer so it's on an hour or two per day? It might be practical if you're away for a few weeks.
Dave W.
Old 11-01-2007, 11:27 PM   #26
brucepick's Avatar
I like this idea:
Originally Posted by DRW View Post
How about simply roll the car back by several cm to move the rust spots around every few days? ...
I suspect the uneven rusting is due to where the pads/shoes are close to the disk/drum. Moving it a bit will change that spot.
We get the same on our Volvos (4-wheel disks) if we leave them parked during a rainy day. If 2-3 days they can sound pretty scary, but it scrubs off after just a couple stops.
Old 11-02-2007, 03:36 AM   #27
GasSavers_bobski's Avatar
Carbon fiber rotors? I'm pretty sure that's what F-1 and prototype cars and such use.
Old 11-02-2007, 04:14 AM   #28
Tuggin at the surly bonds
Silveredwings's Avatar
You could brush them with a solution of Oxysolve and leave a film of zinc phosphate on them. This is usually done for the non-wearing parts but if periodically applied to the braking surfaces (especially since you use the brakes as a special occasion), it may help.
Old 11-02-2007, 04:15 AM   #29
Or ceramic .
Old 11-02-2007, 05:13 AM   #30
Lack of use is a form of abuse.
If you're driving the car that rarely, you might consider selling it and renting instead.
GasSavers_Bruce is offline   Reply With Quote
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 01:50 PM
Weight of Gas Hockey4mnhs General Fuel Topics 15 12-14-2006 09:37 PM
