03-23-2008, 06:59 AM
Originally Posted by vxdude
also along with the speedometer not working the odometer doesnt work either and the shift light. But i think all of that works off of the VSS.
When my speedometer/odometer are not working, my Shift light still comes on.
three stripes the charm!
04-12-2008, 04:38 PM
UPDATE!!!! The VX takes a "special" VSS, its the one at advance auto parts the brand name is Niehoff, Nippon Seiki. Cost anywhere between 100-125. I tried 5 speed senors, then i tried this one. WORKS GREAT. after about 100 miles no problems to speak of yet!!
04-14-2008, 06:38 AM
I have noticed that some D-series Honda trans VSS have metal gears whereas the VX ones are usually plastic.
Does this sound correct from your experience with these VSS?
04-15-2008, 06:39 PM
I dont recall but i will check sometime, although the VSS isnt the issue i think, i will be replacing the speedometer cluster here shortly, still having trouble..grrrrrrrr
04-15-2008, 08:57 PM
I had a CEL on mine once due to corrosion at the VSS plug, but thankfully my 253k mi VSS and cluster are still good in my VX.
06-02-2008, 08:12 AM
Yes Sir the cluster for the speedometer was bad, so instead of replacing the whole cluster with another one, i just replaced the circuit board of the speedometer of the cluster, easy fix
06-03-2008, 09:55 AM
Glad to hear it was an easy fix.
06-03-2008, 04:24 PM
Great! You can come by and fix mine anytime.
