02-17-2006, 09:55 AM
better for the engine to have a valve cover breather and a breather on the intake???
Also would this create a vacuum leak?...
Would it be better for the engine to have a valve cover breather and a breather on the intake???
02-17-2006, 10:00 AM
I'm thinking it will create
I'm thinking it will create a vacuum leak. It's also bad to remove this because you won't be able to expell the oil particles in the crankcase, which will hurt your engine in the long run.
If you really want to prevent the oil from re-entering the engine through the intake, install a catch-can inline with the crankcase ventilation and the PCV line.
02-17-2006, 10:05 AM
Valve cover breathers
Breathers were common 40 years ago, but they were phased out to reduce crankcase emissions which, as I remember, were very significant.....about 30% of total uncontrolled emissions. Adding a breather and removing the PCV valve would be VERY bad for the environment.
The simple breathers were replaced with PCV valves. The PCV valve keeps the crankcase relatively free of water vapor, and the oil last slonger and there is less engine corrosion.
I vote to leave the PCV in.
02-17-2006, 10:09 AM
Yo tambien. Creo que el medio ambiente es mas importante que su coche de mierda.
02-17-2006, 10:45 AM
Re: Valve cover breathers
What the hell are you talking about??? Nobody mentioned anything about a PVC. I said valve cover. You know the hose that goes from the valve cover to the intake. That one.
02-17-2006, 10:51 AM
Why such hostility? I don't know how you're going to get people to help you if you're always rude to them.
02-17-2006, 10:53 AM
If I remember correctly the
If I remember correctly the hose that goes from the valve cover to the intake is the pcv line.
02-17-2006, 10:55 AM
Re: If I remember correctly the
That would be incorrect, but it's a very common mistake. No need for anyone to be all hostile over a common mistake.
02-17-2006, 11:03 AM
The pcv line has the
The pcv line has the charcoal canister on it already, right? Squarey looking black thing on the b2?
02-17-2006, 11:09 AM
FE nut
It seems to me that I've heard that the hose being discussed is used for some type of a balancing effect for the PCV system. Is this correct?
2007 Prius,
Team Slow Burn
