Ford Taraus trans. oil change ? HELP - Fuelly Forums
Old 10-21-2007, 06:50 AM   #1
I have changed my own engine oil for years but have never done my own transmission oil change. Would it be that hard on this vehicle ? What all do I need ?
What type of atf do you recommend ?
Thanks,
Raz
RazBarlow is offline   Reply With Quote
Old 10-21-2007, 06:57 AM   #2
It shouldn't be too hard, I'd just read up on the procedure in a shop manual and make sure to follow it...
I don't know what kind of ATF you would need, last time I did an auto oil change I just used honda stuff,
Old 10-21-2007, 07:00 AM   #3
Do you usually just pull the pan off ? I haven't noticed a drain plug.
Thanks,
raz
Old 10-21-2007, 07:03 AM   #4
On the 2004 civic I did there was a drain plug somewhere...I suggest looking at a manual or having someone in the know tell you how to drain it.
Old 10-21-2007, 07:09 AM   #5
if you don't have a repair manual, get one($15-20)! IF your ford is like my domestic(olds). besides the right size socket and wrench, a torque wrench would be great. get a catch pan of course and newspaper to catch spillage after dropping the pan.
my filter twists(turns) and pops right out. you may need a seal puller to get the seal out. or, VERY carefully pry it out w/ a screw driver. i coat my new seal w/ tranny fluid to help insert it, then tap gently w/ a rubber mallet.
go w/ amsoil ATF--best lube plus drops temp 75 degrees. i do not recommed flushing the tranny. contrary to popular belief, it is not necessary and could cause damage.
please, get the manual(haynes from auto zone for example) first to help w/ the little quirkes of your particular vehicle. best wishes in your new endeavor!
Old 10-21-2007, 07:10 AM   #6
good thing 'cause i think honda can ONLY take honda ATF(will not accept even amsoil).
Old 10-21-2007, 07:12 AM   #7
Thanks,
raz
pretty sure you gotta pull the pan. theclencher might be able to help you(ford guy).
Old 10-21-2007, 07:12 AM   #8
Yeah, I was doing the 30k for my friend and he's all finicky so I just used all honda stuff to keep him happy...he still saved 300 bucks though,
Never knew honda was exclusive like that though.
Old 10-21-2007, 08:01 AM   #9
2000mc's Avatar
i wouldnt expect it to be unusually hard to do. most likely youre going to have to drop the whole pan. i usually use razors to clean the surfaces, be careful not to gouge the surfaces though. find the torque spec, inch-lb torque wrench, and torque the bolts if you dont like leaks. theres new transmission fluids out, i dont know if they help as much as synthetics. dextron/mercon III is the old stuff now. dextron/mercon IV is new but they typicly just says something like atf for ford/gm automatic transmissions on the bottle. the thing is many places may have both.
2000mc is offline   Reply With Quote
Old 10-21-2007, 10:05 AM   #10
Raz try this procedure from v8SHO.com an AX4N is all the same with a few tweaks . I did the same with my '99 . Use OEM fluid in it , or Amsoil ATF . just sayin.
Where's the Jeep Wrangler forum? Revolution Fuelly Web Support and Community News 2 04-16-2012 09:40 AM
Moving? landspeed General Fuel Topics 7 09-09-2007 01:24 AM
Any advice for the college bound? SVOboy General Discussion (Off-Topic) 45 05-15-2006 12:36 PM
