08-24-2009, 05:47 AM
If its the shocks, you may begin to get abnormal tire wear, even if the alignment is good.
08-24-2009, 06:03 AM
Tire wear is great, not uneven at all. I wouldn't say that rules out shocks, but it doesn't confirm them as the cause of this symptom either...
08-24-2009, 06:14 AM
You can test your shocks quickly. Stand on your bumper on each corner of your car and jump up and down. When you stop, does the truck stop bouncing? If it goes past centering itself, it's time to replace the shocks.
08-24-2009, 08:35 AM
Site Team
Most shocks should be replaced every 50k miles. They aren't just a comfort feature, they are a safety item. But they shouldn't cause the symptoms you describe here.
Vis-a-vis the brakes:
1) Did you properly break-in the brakes?
2) Do you have high quality rotors or made-in-china? The chinese crap always seems to warp, so I always pay more for made-in-USA.
3) How do you know your rotors aren't warped? You can't see a warped rotor.
4) I've heard of a practice called indexing the rotors. Basically your rotor can go on 5 different ways (or six or eight if you have a HD truck with more lugs), and you measure the runout on the rotor in each position to find out the place with the most even braking feel.
5) Sometimes your pads will "infiltrate" (corrode to) the rotors, especially if the vehicle is parked for a while in the same position. You can turn the rotors to eliminate this, or just replace the rotors. (This happens more with a particular type of pad, but I can't remember whether it is ceramic or organic)
6) If you have a frozen caliper, that could cause uneven wear on the rotor, which would lead to excessive heat on one side of the rotor, and therefore warpage.
-BC
08-24-2009, 08:44 AM
Site Team
By the way, that vibration could also be caused by over-torqued lug nuts or a bad wheel bearing.
-BC
08-24-2009, 10:12 AM
Some good thoughts there. Addressing each...
1. Break-in: They've been on there for at least two years, possibly longer. I don't remember if I did anything special for break-in, but probably not.
2. Rotor quality: Don't know. Probably good ones, if I got the work done at the garage where I think I did. I wish I could remember.
3. Rotor warpage: I think if they were warped it would feel different. I'm pretty sure I've had warped rotors on other vehicles before and it felt different.
4. Indexing: I've heard of that too.
5. Pad-rotor infiltration: That sounds possible, if a slight layer of pad is stuck to the rotor (and separated from the pad) it could conceivably cause the symptom.
6. Frozen caliper->warped rotor: As I said about the warpage; and, I expect I'd notice but maybe not.
I'll have to try to look at these things in more detail.
Note that I don't feel it in the pedal, just in the seat.
The wheel bearing sounds like the most plausible explanation so far. I go through wheel bearings faster than anyone I know (regardless of what I'm driving; it's my "to hell with it I'll just hit that pothole" style to blame). In maybe 10-12 wheel bearing failures this truck has had, no two had the same symptom, and considering all the past symptoms this could certainly be a wheel bearing.
I'll have to try to test for it...they often pass the wobble and spindown tests when they're bad, but I'll still try.
08-24-2009, 10:26 AM
Only once have I had a wheel bearing fail on me. It was only like 3 or 4 months after I had put brakes on. I was so upset that I had to take the whole thing apart again that now, when I have new rotors put on my vehicles, I just say screw it, its only a little extra, put new bearings in when its put back together. I've never had one fail since.
08-26-2009, 06:20 AM
My $.02 (and I work in a tires, shocks, suspension, brakes shop) is in line with what everyone else says: shocks or wheel bearing. could be front end (steering) but those are pretty easy to find and are either fine, or not. if it's from the rear, I'd do shocks first. front is a toss-up between shocks and wheel bearings. wheel bearings in a solid axle almost never go bad but the bolt in hubs up front are much easier to replace and go bad much more frequently. as for how often you've replaced them, bolt-in hub bearings, especially on GMs, seem to go bad all the time. though the trucks tend to be overbuilt enough to not be a big issue... meh
-Russell
08-26-2009, 06:40 AM
#19
What kind of carnage results from ignoring a failing bolt-in hub bearing? Wheel falls off, or bearing noise just gets worse? Edit: Or it destroys the axle...
Based on this thread, I'm going to guess shocks. It's felt in the seat but not the steering wheel, so it's probably rear.
08-26-2009, 08:11 AM
#20
Roll the windows down, turn off the blower and radio and do some hard turns, you should hear some whine, squeal or growling from bearings starting to go out... however, sometimes you have to do a 30 min highway run before they're warm enough to show up.
I've run them until they've been squealing in straight line driving at 50mph, but even then they're usually quiet for 10-15 mins until they warm up, and you could drive round the city at 30mph all day and never hear them.... They may weld up on a 2 hour+ highway drive if they're squealing in a straight line, and heat may damage brake components. I've never driven them to complete failure, but you'll probably smell burning brake fluid before anything falls off, I guess wheels falling off or folding under is what happens when you realise your brakes don't work and try to swerve.
