02-26-2007, 09:34 PM
Speaking of Manual
I located the shop manual and noted that I can override the TC engagement through manually engaging 1 or both of the 2 TC lockup sensors via 5V power. Judging by the schematics, it may bypass the VSS and TPS to make the final decision to lock up through the switch override -- I'd just have to be mindful of speeds and coolant temps to prevent further damage to the trans. Of the 3 settings of full, partial, or zero lockup, one sensor allows partial, and the other engages full and uses the Hill/Fuzzy-Logic adaptive computer for shifting (argh). So, during the colder months, perhaps 2 toggles could manually engage these at lower TPS settings once the speed allows. Purely theory.
I'll tell ya, that 50-page section on the automatic transmission looks more complicated than open-heart surgery. Sheesh.
If you're stuck with an auto, I reccommend finding a shop manual that describes exactly what parameters the transmission requires. Further inspection could perhaps find a way to take control of that vicious dictator: the Transmission Control Module.
02-28-2007, 01:02 AM
Wow thanks for all the responces! I could swap in a Camero 6 speed transmission. I've had two 5 speed manual cars before. On both, I notice if I short shift, I can get better than the EPA highway milage, in the city. I have a 700r4 transmission in my caprice, I would have trade in the newer electrically controlled one and program differnt shift points.
David
85 Chevrolet. 30 MPG or bust!
02-28-2007, 03:36 AM
A camaro 6 speed will cost you more than a metro
02-28-2007, 12:24 PM
caprice -
I googled " camaro 6th speed manual gear ratios" and found this :
1996 CHEVROLET CAMARO
http://www.media.gm.com/ca/gm/en/pro...996Camaro.html
(Paraphrased from URL)
TRANSMISSION : 6-speed manual w/overdrive
Gear Ratios:
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th 0.74
6th 0.50
Reverse 2.90
03-01-2007, 01:28 AM
and with my gear ratio and tire size, at 75 MPH the engine would be turning 1500 RPM  50 MPH is 1000 RPM. With the low end torque of a 5.7 liter engine, I'd have no problem  If I want a little passing power, I could just down shift.
http://www.f-body.org/gears/
David
