theholycow's sig/link meta-thread (Warning: Contains random and miscellaneous stuff) - Fuelly Forums
Old 09-03-2008, 10:39 AM   #1
Post theholycow's sig/link meta-thread (Warning: Contains random and miscellaneous stuff)
My sig is full...so I might as well move some of it into a thread and just put in a single link to the thread, right? From now on, I'll add things here and send people here to see them rather than trying to squeeze them into my sig.
Open-source ECU tuning for Subaru/Mitsubishi/some Mazda/presumably some Chrysler:
http://www.gassavers.org/showthread....527#post139527
Fuel injector cleaning using DIY chemicals or sending them by mail to be professionally cleaned and tested:
http://www.gassavers.org/showthread.php?t=6648
Another post about professional cleaning:
http://www.gassavers.org/showpost.ph...4&postcount=31
See also a BITOG thread where it seems like Gumout Regane and Redline Sl 1 are the best store-bought cleaners and BG 44k is the best you can get:
http://www.bobistheoilguy.com/forums...Number=1142046
More DIY injector cleaning ideas (remove injector, pressurize with aerosol can of cleaner, fuel pump, or vacuum pump)
http://www.gassavers.org/showpost.ph...9&postcount=13
Lug patterns (bolt circle diameter):
http://lugpattern.net
An old list of DIY modifications...
http://www.gassavers.org/showthread.php?t=2692
Why MPG (or any Distance Per Volume) can be a difficult measurement to use instead of l/100km (or any Volume Per Distance):
http://www.gassavers.org/showpost.ph...0&postcount=19
Why using higher octane rated gas isn't going to help FE or power:
http://www.gassavers.org/showthread....636#post129636
Honda factory service/repair manuals for 1987 Civic, 1992 Civic, 1996-1998 Civic, 1993 and 1994 Integras, and wiring diagrams for 1988 Integra:
http://www.redpepperracing.com/technical/main.php
http://www.honda-tech.com/showthread.php?t=1998336
http://www.spoonertuner.com/manuals?...c9ef14fe962b31
http://www.honda-tech.com/showthread.php?t=2053807
http://www.hondahookup.com/manuals/
Exploded parts diagrams for Hondas: http://www.hondaautomotiveparts.com
http://hondatech.info/downloads/Auto/Manuals
"DeSchlong's" DIY Install Guides for the 5th Generation (5G) 1992-1995 Honda Civic.
Honda wiring and pinouts
Also, general sources for Haynes/Chiltons style manuals:It looks like Bentley ( http://www.bentleypublishers.com ) doesn't offer online content, but most of the other repair manual companies (Chilton's, Helm, Alldata) offer online access for a fee.
Upgraded exhaust system: Good for FE, or not helpful?
http://www.gassavers.org/showthread.php?t=10274
Why fuel-saving devices, additives, and other products don't work:
My intro to hypermiling:
http://www.gassavers.org/showthread.php?t=7781
Glossary and busted/confirmed FE mods/stratgies:
http://www.gassavers.org/showthread.php?t=1088
Glossary and acronyms:
http://www.gassavers.org/showthread.php?t=7428
Calculators/formulas:
Tire size calculator with non-metric sizes:
http://www.1010tires.com/tiresizecalculator.asp
Tire size calculator that specializes in equivalent diameter listings:
http://www.tiresizecalculator.info/
http://ejelta.com/tiresize
Gear calculator:
http://f-body.org/gears
Tire size calculator with equivalent size list:
http://www.wheelsmaster.com/rt_specs.jsp
A tire and gear calculator in the form of a Microsoft Excel spreadsheet:
http://www.gmfullsize.com/forum/showthread.php?t=80330
Collections of calculators mainly for off-road truck configurations but may be useful for other purposes:
http://www.4lo.com
http://www.ringpinion.com/Calculators.aspx
Another tire size calculator somewhat like the miata.net one in my sig
http://www.roversd1.nl/sd1web/wheelcalc.html
This one has more detail about gear ratios and requires you to enter more data, but calculates more driveline data.
Time to payoff for buying a more expensive, more efficient vehicle vs. a cheaper, less efficient vehicle:
http://www.sporkforge.com/finance/gas_cost.php
Best cruising speed (didn't work for me):
http://www.gassavers.org/showthread.php?t=7130
Drag coefficient:
http://www.gassavers.org/showthread.php?t=4904
http://www.gassavers.org/showthread.php?t=5904
Aerodynamic drag, rolling resistance, and a whole bunch of other stuff:
http://metrompg.com/tool-aero-rr.htm
Effect of air pressure changes due to temperature:
http://wahiduddin.net/calc/calc_hp_abs.htm
Aerodynamics:
Drafting distance:
http://www.gassavers.org/showthread....4033#post94033
Cd vs. CdA -- how aerodynamic drag coefficient actually affects your MPG:
http://www.gassavers.org/showthread.php?t=8487
Tool for visualizing aero vs rolling resistance:
http://www.gassavers.org/showthread.php?t=601
Research on Aerodynamic Drag Reduction with Vortex Generators:
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
The effect of boattails and other aerodynamic modifications on tractor trailers:
http://www.nasa.gov/centers/dryden/p...ain_H-2283.pdf
http://permanent.access.gpo.gov/webs...00-01-2209.pdf
http://www.greencarcongress.com/2005...at_tail_d.html
There's diagrams in those links that show the airflow around trucks, which may help car drivers better understand drafting.
Other:
Search junkyards (sorry, "auto salvage yards" (oops, "used auto parts dealers" (I apologize for my political incorrectness, "auto recyclers"))) nationwide for the part you need:
http://www.car-part.com
Air filters tested -- paper vs. K&N vs. other brands, and so on:
http://bobistheoilguy.com/airfilter/airtest1.htm
More on K&N air filters:
The generally accepted authority for questions, data, and myth-busting about motor oil:
(Keep in mind that it is still a forum and has plenty of people who subscribe to all the myths without an ounce of skepticism.)
Weight: Does it really make that much of a difference? Well, not for bicyclists:
http://www.gassavers.org/showpost.ph...1&postcount=39
More on weight reduction, with actual measured results:
http://www.gassavers.org/showthread.php?t=8361
When it's all said and done, some cars can have a measurable FE difference of ~1% MPG per 1% weight change -- so, to get a 10% change in MPG, one would add/remove 230 pounds on a 2300 pound Civic. Other cars may not respond to weight loss at all, such as a 2.5% MPG change resulting from a whopping 19 percent weight change.
Stuff that's still in my sig:
Hypermiling/FE "sleepers" -- cars that get better FE than expected or respond particularly well to hypermiling techniques:
http://www.gassavers.org/showthread.php?t=7449
Good threads about drafting:
http://gassavers.org/showthread.php?t=7219
- In summary: A draft at highway speeds extends to three times the length of the vehicle, resulting in a 2 to 3 second following distance behind standard sized tractor-trailers -- that's not close, probably further than you were going to be anyway.
My DIY fuel rate meter thread:
http://www.gassavers.org/showthread.php?t=7714
- Also contains links to many other DIY fuel rate meter / MPG meter / electronic info threads
Tire pressure myths, facts, observations, effects:
http://gassavers.org/showthread.php?t=7712
In summary: You would probably benefit from additional tire pressure.
The effect of tire width on rolling resistance:
http://gassavers.org/showthread.php?t=7713
Low rolling resistance tires, which models are good:
http://gassavers.org/showthread.php?p=110803
Tire size calculator -- tells you the difference in diameter for any two sizes, and calculates speedometer/odometer error (and therefore your fudge factor for figuring your FE):
http://miata.net/garage/tirecalc.html
You're probably not actually lugging your engine when you use too high of a gear, just making it growl a little:
http://gassavers.org/showpost.php?p=100910&postcount=13
Lowest gas prices from websites approved by the EPA (instead of the junk spam we get advertising such sites):
http://fueleconomy.gov/feg/gasprices/states
O2 sensor for Honda Civic VX:
http://www.gassavers.org/showpost.ph...10&postcount=4
http://stores.channeladvisor.com/Aut...-36531-p2m-a01
http://www.gassavers.org/showpost.ph...8&postcount=46
Old 09-03-2008, 11:56 AM   #2
|V3|2D
thisisntjared's Avatar
nice FAQ
motion to stickie.
Old 09-03-2008, 02:51 PM   #3
I second the motion... Let's sticky it.
Old 09-03-2008, 04:24 PM   #4
Really? I only posted it so I could make some room in my sig...
What can I say, I'm flattered.
Old 09-03-2008, 07:14 PM   #5
Snax's Avatar
JB Weld that sucker.
LiberalImage.com
I think, therefore I doubt.
Old 09-03-2008, 07:31 PM   #6
I love JB weld. I keep a tube in my desk at work. I've never had to fix sonething a second time after I JB Welded it.
Old 11-11-2008, 08:22 AM   #7
Today's edit: Added vehicle comparison FE payoff calculator http://www.sporkforge.com/finance/gas_cost.php
Old 02-26-2009, 03:16 AM   #8
Added link to very informative exhaust thread:
Old 03-03-2009, 08:06 AM   #9
Added links for service manuals.
Old 03-08-2009, 04:07 AM   #10
Added bobc455's octane explanation:
