engine off danger to trans? - Fuelly Forums
Old 05-31-2011, 05:17 PM   #1
farmerjohn's Avatar
I've got a 3speed auto trans,
tried shutting engine off in Neutral on long downhills, with key in ON postition there is a strange noise as if the engine is still ON but with no power, afraid this is not a good idea...can this damage anything?
with key in off position and coasting downhill the noise and drag are worse
any ideas what happens to auto-trans engines in glide/off?
thanks
john
farmerjohn is offline   Reply With Quote
Old 05-31-2011, 05:19 PM   #2
Re: engine off danger to trans?
id stop doing it, some auto trans dont pump fluid when the engine is off and your slinging it all outa the torque converter which is not good.
neutral and coasting engine on is fine
Old 05-31-2011, 07:09 PM   #3
Look in your owners manual. If it says that flat towing is not recommended for your car, then engine off neutral coasting is not recommended either. If you want to coast in neutral, leave the engine idling so the transmission pump is still running and circulating fluid through the transmission.
Old 05-31-2011, 08:02 PM   #4
farmerjohn's Avatar
Thanks Vette and Jay,
Pretty sure it's not towable, that explains it. Greatly appreciated help!
john
Old 06-01-2011, 07:00 AM   #5
FrugalFloyd's Avatar
Yes, make sure it is towable before trying engine-off coasting. Don't try it if it's not towable with all four wheels on the ground.
Incorrect photo displaying wiskow Fuelly Web Support and Community News 2 06-18-2011 02:37 PM
1-800-Radiator shatto General Maintenance and Repair 2 04-24-2009 02:59 PM
What does EG and EK mean? Tepco General Maintenance and Repair 7 01-05-2008 11:28 AM
Test AnthrAxNSB Fuelly Web Support and Community News 0 12-08-2007 06:53 PM
Do gals not want to save gas? zpiloto General Discussion (Off-Topic) 22 01-19-2007 08:54 PM
