Adding Service Record from multiple reminders - Fuelly Forums
Old 03-08-2021, 08:28 AM   #1
Question Adding Service Record from multiple reminders
Is there a way to add one service record from multiple reminders? I would like to use my reminders to go through and complete my regular service, but I don't see a way to add a Service Record and select which services I am completing from the reminders.
For example, I am doing my 20,000 mile service and I would like to add a new Service Record and just check off the items that are due from my reminders. Air Filter, Oil, Oil Filter, Check Battery... Instead, it seems that I have to add a Service Record, then remember what items are due and add them. That doesn't make sense to me.
Any tips?
DaveDelux is offline   Reply With Quote
Old 03-08-2021, 10:08 AM   #2
Hi,
I only have one Reminder ... if I long press on the Reminder I can then tap on Service Rec to record that item on the Reminder.
It may not be how you setup your Reminders now, however, a Reminder could be setup for each item you wish to record.
HarvMan is offline   Reply With Quote
Tags
service records, service reminders
