Brisk spark plugs - Fuelly Forums
Old 07-30-2007, 07:51 AM   #1
unstable bob's Avatar
Send a message via AIM to unstable bob
Thumbs up Brisk spark plugs
I just installed some Brisk plugs in my Cavalier, and will be filling up in a couple hours to start testing. I will say the car seems to idle much smoother, and at a lower RPM.
http://www.briskracing.com/content/lgs.php
unstable bob gable
AMERICAN ROAD WARRIOR!
www.unstablebobgable.com
1973 AMC AMX: The beauty
1987 Buick T-Type: The beast
unstable bob is offline   Reply With Quote
Old 07-30-2007, 09:00 AM   #2
cfg83's Avatar
Unstable Bob -
I keep thinking I have seen all the spark plugs out there, but there's always a new one I have never heard of. A "no indexing" firing tip in a Lambo, of all things? Maybe this is the secret to theclencher's success.
I have Denso Iridiums that seem to be working fine right now, but Saturns also use a "waste spark" system that reverses the polarity of the firing of the plug :
Spark Plug Comparison Test
http://www.gassavers.org/showpost.ph...8&postcount=19
I think your Ecotec does as well :
INVESTIGATING GM'S COMPRESSION SENSE IGNITION
http://findarticles.com/p/articles/m...11/ai_n9469461
... The ECOTEC engine uses a speed density-based fuel injection system, along with a waste-spark electronic ignition system. The waste-spark ignition is part of a unique Compression Sense Ignition (CSI) system that allows the powertrain control module (PCM) to determine proper engine phasing (cam position) without the use of a separate camshaft position sensor mounted near a rotating engine member. This article will explain how the CSI system operates. We'll also document new misfire diagnostic techniques that are made possible by die system s unique design. ...
I will be interested in your long term performance because I read at saturnfans that certain spark plug designs are susceptible to being fouled more quickly than others. My Denso's should be vulnerable, but they're working like a charm (knock on wood).
Old 07-30-2007, 08:52 PM   #3
Thumbs up
Originally Posted by cfg83 View Post
Unstable Bob -
Carlos:
Some interesting points there. I'll add "checking spark plugs" to my list of things to moniter.
unstable bob gable
Old 08-04-2007, 06:47 PM   #4
Thumbs up
My mileage for the tank I used while running the Brisk plugs gave me 36 MPG, up from 35. And this was with some "spirited" driving. Car seems to be running really well, and as noted has a very smooth idle @ a lower RPM then stock.
unstable bob gable
Old 08-04-2007, 09:03 PM   #5
Which reminds me, I need to check mine tomorrow
If you don't have a spark plug socket, it's ok to use a cresent wrench, correct?
Old 08-04-2007, 09:09 PM   #6
cfg83's Avatar
unstable bob -
Can you recall the before/after idle RPM? You can quantify your gas savings "at idle" with a simple RPM ratio.
Old 08-10-2007, 08:09 PM   #7
unstable bob,
Ditto on the (Can you recall the before/after idle RPM?) question from Carlos...
And which spark plugs exactly with model number did you replace with these Brisk ones?
~Will
-unknown
Old 08-10-2007, 08:22 PM   #8
Thumbs up
Originally Posted by n0rt0npr0 View Post
unstable bob,
~Will
Oh snap! I forgot about this thread...
IIRC, the idle went from 700ish to low 600-high 500ish. Didn't really think to do a before and after check. The plugs I replaced were AC-Delco 41-981s.
unstable bob gable
Old 08-10-2007, 08:24 PM   #9
GasSavers_Red's Avatar
Why is your Cavalier idling at a lower RPM? Far as I know its a computer controlled vehicle, so its idle should be more or less hard coded into the ECU. Logically speaking, plugs shouldn't change your idle speed
Old 08-10-2007, 08:40 PM   #10
Thumbs up
Someone else brought this up, and I really don't have an answer for it. *shrug* Guess it is like the azz dyno, you know the gains are there, but can't really prove it...
unstable bob gable
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 09:17 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 03:08 AM
Text box for the odometer? codemunky Fuelly Web Support and Community News 1 09-03-2008 12:12 AM
Automatically add the 9/10ths of a penny on to the gas price Saiyaman156 Fuelly Web Support and Community News 1 08-10-2008 01:23 AM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-23-2006 11:17 PM
