Grill block questions - Page 2 - Fuelly Forums
Old 10-30-2007, 12:35 PM   #11
Originally Posted by Danronian View Post
Wow that is a tank. Great cheap mod! I also made mine with some thick plastic I found at work a few years back. Works great for me.
Great to see you are getting better mileage with your "tank."
thanks, do you have close-up pics of your grill block? couldn't see from your garage pic.
if it's there, it's very clean looking!
Old 11-02-2007, 06:19 PM   #12
is a grill block used to make the engine warm up faster, run hotter or to reduce airflow through the engine compartment?
https://www.bestamericanoil.com
smay665949 is offline   Reply With Quote
Old 11-03-2007, 02:48 PM   #13
warm up faster AND reduce airflow. in florida, my concern is mainly the aero benefit(reduce thru airflow). as far as hotter engine, i put in a 195 degree thermostat. this is for peak efficiency.
Old 11-03-2007, 06:02 PM   #14
brucepick's Avatar
Kewl!
You upped the mpg from about 25 to about 30 - about a 20% increase right there.
I built a new grill block too - am guilty of NO PICS yet. I promise, I promise...
How hard are you running your tires?
I upped mine a few psi at a time as I got used to the handling changes.
Are your tires rated 44 psi so you know you can get the psi up pretty high?
(With 35 psi tires I probably wouldn't have the nerve to go over 40 but that's just me.)
Old 11-04-2007, 06:51 AM   #15
Originally Posted by brucepick View Post
Kewl!
yes 44 rating. going 60 front, 55 rear. haven't noticed a harder ride, just lighter steering.
Old 11-04-2007, 04:23 PM   #16
brucepick's Avatar
Yeah, lighter steering here too.
Mine are rated 44, running them at 48 front and 46 rear.
Feels pretty hard - but I think that's cause the suspension was designed around running tires between 27-32 psi. I've far exceeded the expectation there!
Steering is light enough that I'm considering removing the belt that runs a/c and power steering. All the Volvo guys say it will be a bear to steer but I wanna try it when I get a chance. They don't drive on 48 psi tires.
Old 11-08-2007, 04:01 PM   #17
Antares2k6's Avatar
grill block
I have a 91 Cutlass Supreme and have been wanting to do a grill block of sorts. Do you plan on blocking off below the bumper? Just above the bumper? Need to do something after not a good mpg test this week.
Antares
Originally Posted by bowtieguy View Post
FINALLY got my garage pics w/cheapy grill block(top and bottom). very cost effective(everything already in house): foil tape, expanding foam, and silver paint. looks cheap 'cause it IS! what do you guys think?
www.gassavers.org/garage/view/775
Antares2k6 is offline   Reply With Quote
Old 11-08-2007, 04:51 PM   #18
hmm i gotta do somehting to help with the cold, BUT i do not have a temp guage in my car, just a temp warnign light (that most likely comes on after its too late)
im thinking a veyr thin piece of sheetmetal that we have and ziptie it in front of my grill, if it helps alot maybe ill do it permenately but behind it(less of an eyesore, no offence to anyone else tho)
Old 11-08-2007, 05:09 PM   #19
Antares,
forgive me if i misunderstand your question. but, i have blocked both above and below the bumper. if you click onto my garage link and then enlarge the frontal view, you'll see the lower grill block. both are left partially open because temp concerns here in florida.
BTW, is your gas log accurate? 60mpg on a recent fillup?
Old 11-08-2007, 05:15 PM   #20
Antares2k6's Avatar
I did not put one or two of them in km's. Live in Canada, should have done that.
Antares
Antares,
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 06:32 AM
super mid Hockey4mnhs General Fuel Topics 5 06-03-2007 12:57 PM
HF to SI tranny swap complete, questions about tire size... white90crxhf General Fuel Topics 1 08-20-2006 06:46 PM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 01:21 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 02:44 PM
