88 CRX HF tranny swap questions.... - Page 3 - Fuelly Forums
Old 04-05-2007, 06:35 PM   #21
UfoTofU's Avatar
I do plan to clean it and replace the drive shaft seals while I got easy access to it. I will probably clean it up real nice since it will be a while before the swap is attempted anyhow.
It seems I will be getting a job that I will need an automatic for.
Thanks for the response. I thought maybe the tranny mount looked like it was bent a up a little. I thought that it was supposed to align parallel to the barcode sticker that is on there.
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 04-05-2007, 06:59 PM   #22
I think the mount is bent. And I sent you a new throwout bearing, so,
Old 04-05-2007, 07:16 PM   #23
UfoTofU's Avatar
I didn't even realize the bearing was in there until I just now checked. I only pulled out the clutch, flywheel and pressure plate and fondled them for a few minutes.
I thought it looked off kilter. Damn. Looks like I will have to get all new mounts anyhow.
I believe that I will need 3 mounts (front side rear) just for the tranny is that right?
What year car would I need the mounts off of? Or is it better to go after market?
- UfoTofU
Old 04-05-2007, 07:30 PM   #24
I pulled mine off a crx si in the junkyard, I think any ef will do.
Old 04-06-2007, 06:04 AM   #25
Moderator
GasSavers_DaX's Avatar
I purchased my mounts from a guy that was doing a B-series swap in a 90 Civic STD hatchback. Don't forget to get the rear mount AND bracket.
I do think the mount is bent.
The ding near the axle hole isn't too bad - try popping an axle in it without bending it back first - you may be ok - it looks like its just a dust seal.
I recommend taking a flat head screwdriver and scraping off as much of the caked up gunk before you go spraying the thing down with brake cleaner. You'll use a lot less this way, and it's about $3/can.
I can't really speak much on the transmission by just looking at it's exterior. If you plan on doing a rebuild, then I'll be more than happy to help you (as best I can). It looks like you got a great deal, just take your time with it.
Old 04-06-2007, 07:00 AM   #26
UfoTofU's Avatar
Thank you guys for all your answers and input as well as putting some of my fears at ease as well as confirming some of them.
- UfoTofU
Old 04-06-2007, 07:18 PM   #27
UfoTofU's Avatar
I magically turned my tail lights into......
these parts :
- UfoTofU
Old 04-07-2007, 04:28 AM   #28
Moderator
Well there you go.
Old 04-08-2007, 06:17 PM   #29
UfoTofU's Avatar
Unfortunately I found out that my clutch will not fit on the input shaft of the 88HF tranny that I got.
The clutch, as well as the pressure plate and flywheel are off of an 89 Honda kit.
Would I be able to use the other parts and possibly just get a new clutch instead? What parts (if any) will I be able keep and not have to replace?
- UfoTofU
Old 04-08-2007, 06:54 PM   #30
The flywheel is actually from an eg I think. All 90-00 flywheels are the same besides the cx and vx being 3 pounds lighter.
Poll: Should Stability Control be Standard rh77 General Fuel Topics 14 09-30-2006 09:44 PM
Evo-Style Vortex generators? cfg83 Aerodynamics 5 09-21-2006 10:09 AM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 07:53 AM
Friction Reducer kjvman General Fuel Topics 1 01-22-2006 06:52 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 03:38 PM
