Frank's mpfi/obd1 swap list - Fuelly Forums
Old 12-18-2006, 05:37 PM   #1
I would like to compile a list of things I will need to do this, if I do this.
I have a stock 91 civic std (d15b1/dpfi/obd0)
I don't know which im/tb/dizzy/ecu etc i need, so if anyone knows I can start looking.
missing anything here?
b7 im
b7 intake arm
b7 tb
dx dizzy
p06 ecu
ecu plugs
thanks guys.
budomove is offline   Reply With Quote
Old 12-18-2006, 05:41 PM   #2
You look good, there might be something I'm forgetting, but nothing too serious, I ought to write it up one of these days. Wish I had my camera with me, boo my foolishness.
You can use any old IM/TB, but to match the ehad best I would use DX stuff. I happen to have an obd1 dx IM laying around,
Old 12-18-2006, 05:52 PM   #3
Ben, do i need a chipped ecu or a dx ecu (p??)?
I'd be interested in buying your im if i cant find an integrated im/tb.
is the wiring a pain? what is the easiest way? buying a new harness? If I want to modify my current wiring would that be hard or much more time consuming? Thanks!
Old 12-18-2006, 05:56 PM   #4
p06, wiring is easy, use the old hardness, you need to and it's easy.
Old 12-18-2006, 06:00 PM   #5
Cool. Is it neccesary to go obd0>obd1 in order to do an mpfi swap?
Old 12-18-2006, 06:05 PM   #6
What is "ehad" and is there any benefit of using the dx im as opposed to a cx im? Anything wrong with using the 88-91 b8 im or the 92-95 b7 im?
maybe mpg diff's b/w the dx and cx? would i then have to use a diff ecu?
Old 12-18-2006, 06:12 PM   #7
You don't need to go obd1.
The DX IMs will match your intake ports better, and the b7 IM is prettier than the crx/civic si one.
Old 12-18-2006, 06:26 PM   #8
if the b7 (same as b8?)im lines up, fuel efficiency wise which im should i go with? do you know if i would run into probs with the b7 im not lining up well enough?
Old 12-18-2006, 06:30 PM   #9
b7 is DX, b8 CX. I'd use the b7, because the b8 will have ugly air flow. *shrug*
Old 12-18-2006, 06:39 PM   #10
cool, I am now starting to read on h-t about mpfi swapping!
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
Incorrect photo displaying wiskow Fuelly Web Support and Community News 2 06-18-2011 02:37 PM
A radiator door for the grill block basjoos General Fuel Topics 26 04-20-2006 06:51 AM
what will the scangauge fit? GasSavers_Ryland Hypermiling 11 03-29-2006 07:15 PM
My small changes helped my gas mileage. Screw 26mpg, I overshot it like crazy. Compaq888 General Fuel Topics 4 11-01-2005 07:38 PM
