Manual Trans is stuck!!! - Fuelly Forums
Old 05-11-2009, 01:37 PM   #1
Im pulling the manual tranny and am at the point where it should just slide off but it is stuck i double checked that all bolts were out and they are i can open the seam between the block and tranny just a little but cannot seem to pull it off.
Does the transmision have to be in nuetral for it to come off
domggg is offline   Reply With Quote
Old 05-11-2009, 04:13 PM   #2
jadziasman's Avatar
I just sent you a PM in case you overlook it.
Old 05-11-2009, 07:41 PM   #3
ok i got some good news and some bad news
good news is i got the trans off there was a hidden bolt under the starter i didnt see
the bad news is that before i realized there was an extra bolt i took a mini sledge to it and cracked the part of the trans that the shifting linkage connects
So first im gonna try to weld it or something and if taht doesnt work its time for a tranny
what do people usually swap their transmissions for? what will work for the vx without changing the stock clutch?
oh and im still in highschool and this is my only car so i want it running asap walkin sucks
Old 05-12-2009, 02:19 AM   #4
I'm pretty sure anything other than a VX trans will reduce your FE.
Old 05-12-2009, 05:37 AM   #5
kamesama980's Avatar
I did that once. someone other than me had the bright idea of tow-strapping the trans to a riding lawnmower and long story short, pulled the car off the jackstands. except we didn't break anything.
generally, unless it's suspension rusted together for 20 years, you don't need a hammer. oh and you almost never need a hammer on the engine or trans.
-Russell
Old 05-12-2009, 06:23 AM   #6
GasSavers_bobski's Avatar
If just the case is damaged, you could get a manual trans from some other '92-95 Civic and drop in the VX gear stacks and differential (really just the ring gear).
Old 05-12-2009, 11:16 AM   #7
I kno i shoulda never took a hammer too it i feel so stupid all it was was a bolt now i got a car on jack stands im thinkin bout jus gettin any trans and slappin it on cause i just wana be able to drive
Old 05-12-2009, 11:49 AM   #8
Don't feel too bad about it. You're not the only one who has done that...I've destroyed plenty of things the same way.
Old 05-12-2009, 11:57 AM   #9
I just found a tranny off a 92-96 ek civic d16y7 will it bolt rite up to my block and other trans mounts
Old 05-12-2009, 12:54 PM   #10
It should bolt up to the block. I'm not sure about the mounts though - you may need to use some of the EK mount parts.
Total gallons used? srellim234 Fuelly Web Support and Community News 3 03-24-2009 04:10 AM
California smog/registration question roadsterbum General Maintenance and Repair 8 02-23-2008 02:41 AM
canola rollaz DRW General Discussion (Off-Topic) 5 10-24-2007 03:58 PM
City guy, always a thinkin.. APBIowa Introduce Yourself - New member Welcome 7 03-24-2007 04:15 AM
92 Civic 1.5 engine work with CRX? UfoTofU General Fuel Topics 4 10-08-2006 05:50 PM
