Seafoam lowered my idle! - Fuelly Forums
Old 11-13-2007, 02:23 PM   #1
Danronian's Avatar
At first I was a bit scared of using this stuff, but I figured if so many people have success with it, who not give it a try.
My VX used to always idle at about 900 RPM when it was fully warmed-up instead of around 500 RPM like it should. Aftering using Seafoam, it idles low just like it's supposed to!
It was a bit scary seeing that huge cloud of white smoke behind the car, and hearing it idle terribly with the brake-booster vaccum line detached was annoying, but it was worth it. After I took it to redline a about a dozen times on my drive to "clean out" the motor, the engine stopped smoking, and now idles better than ever!
Great product! I added some to my gas and oil too to hopefully give the engine a full cleaning.
Old 11-13-2007, 02:34 PM   #2
GasSavers_TomO's Avatar
Congrats, chalk another one up to Seafoam.
Honda Civic VX Info/Links
Old 11-13-2007, 03:02 PM   #3
Danronian's Avatar
Thanks! I'm quite impressed it actually made a difference. I'm pretty much of a skeptic when it comes to anything additive-like.
Old 11-13-2007, 04:16 PM   #4
1993CivicVX's Avatar
umm, shortly after I bought my car I brought it to Jiffy Lube where they did a similar thing. I didn't think it was seafoam they used, but your description is very similar to what they did. They said it was cleaning out the exhaust system, though, and never mentioned seafoam. Was it something else they did? I'll have to dig up the post I made about it.
three stripes the charm!
Old 11-13-2007, 09:05 PM   #5
Danronian's Avatar
Originally Posted by 1993CivicVX View Post
umm, shortly after I bought my car I brought it to Jiffy Lube where they did a similar thing. I didn't think it was seafoam they used, but your description is very similar to what they did. They said it was cleaning out the exhaust system, though, and never mentioned seafoam. Was it something else they did? I'lhttp://www.gassavers.org/showthread.php?t=975
Donate to GasSavers. Upgrade your membership! Remove Ads! l have to dig up the post I made about it.
I've actually never gone to a jiffy-lube type place, but I have heard the Honda dealer does something very close to Seafoam on used cars. Now that I've been driving it a while, I'm starting to notice that it actually accelerates smoother now, and I can actually drive even slower than before in 5th before the car wants to die. Good news for MPG I hope. This is looking to be a record tank for the car, so I hope I'm not just being too hopeful!
I really need to get the complete OEM intake installed though... The way I have it in there now, it is still sucking cold air, which can't be good with these COLD temperatures around here lately. HOpefully I'll get it installed tommorrow so it will suck up only engine-bay air.
Old 11-13-2007, 09:42 PM   #6
trebuchet03's Avatar
^^ Mazda has a seafoam type stuff for their cars... The KL series engine is non interference, unless carbon build up on the valves gets really bad (ya, tolerances are damn tight) - to the point where carbon knock is an issue. The TSB says to use their version of seafoam, but to let it soak overnight (or maybe it was 60 minutes?).
11/12
Old 11-13-2007, 10:18 PM   #7
Hateful's Avatar
Send a message via AIM to Hateful
I'm going to skip the seafoam issue, but you can reroute your intake to near the headers or cat converter. Just remember not to bypass any air filters( I installed an after market filter). Also sometimes the O2 sensor is in the intake hose,so don't bypass that either( I connected the new hose to the old one to keep the sensor.
Hateful is offline   Reply With Quote
Old 11-14-2007, 04:53 AM   #8
GasSavers_bobski's Avatar
That would be the mass airflow sensor or possibly intake air temperature sensor. Oxygen sensors are always in the exhaust system some place.
Old 11-14-2007, 06:19 AM   #9
Danronian's Avatar
The factory civic intake actually pulls all of its air from the engine bay (minus the resonator box, but I'm taping off that hole for that and am not installed that heavy box), and with a small modification, I could have it pull all of the air from the header area with about a 1ft addition. I'll have to take a picture of what I'm talking about once I get it installed.
Old 11-14-2007, 06:57 AM   #10
^^^ sounds like what I did with my stock VX intake. I left the resonator box behind the bumper and all the other OEM piping in place. All I really did was get some aluminum dryer vent (expandable kind) in 3" diameter. Then I just sccrunched it over the top of the intake tube that sits behind the radiator and directed it over to between the manifold and the block.
Full tank of fuel or not? elvyn General Fuel Topics 9 03-24-2010 10:53 PM
Car trouble woes Fourthbean General Maintenance and Repair 10 07-30-2007 04:54 AM
XFi Drivetrain For Sale ... Perkasie, Pa XFi For Sale 17 12-17-2006 04:11 PM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 12:43 PM
Sticker Shock -- Inefficient New Furnace rh77 General Discussion (Off-Topic) 8 01-25-2006 06:15 AM
