SGII someone guide me... - Fuelly Forums
Old 09-18-2008, 08:35 AM   #1
I've had my SGII for a while now and I cannot seem to get it dialed in enough to produce accurate readings.
What do I do about the cutoff value? This is in my '96 SL2, I tried leaving it at 24, info was innaccurate, I tried setting it to zero, info was innaccurate.
I set, and saved, all vehicle info, engine size, fuel type, tank size, I even added 1 to the engine speed because I put slightly bigger tires on the car than OEM.
I can never get the "to empty" to be accurate and I can never get the average MPG to be accurate.
Anyone know what MODE to put in for an SL2? I think it reads VPW when in MODE.
Just getting frustrated w/ displays not being accurate.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 09-18-2008, 08:45 AM   #2
GasSavers_BEEF's Avatar
do you know about the calibration procedure?
there is a place to put in percent of error.
also you will have some difference just by how full you fill your tank at different fill intervals. it usually isn't much but it will be different from your average.
Old 09-18-2008, 09:33 AM   #3
Yes I know about the calibration procedure, I just re-read the book for the 10th time in fact, lol.
The first fillup you hit done, then next time you adjust the value to match it up.
Everytime I've done that I've had to keep adjusting and keep adjusting each fillup after that because the values never matched. Like it would say I consumed 7 gallons but I acutally consumed 10, so I adjusted, later it would say I used 8 gallons but actually used 10, so adjust again. Eventually it got to where my calibration value was like 65% so I just reset the SGII and started over. Went through this twice now...
John
'01 KTM Duke 2
Old 09-18-2008, 10:31 AM   #4
do you have the correct tank size entered? what about stock sized tires?
Old 09-18-2008, 10:42 AM   #5
probably a stupid question but, are you filling your tank consistently? stopping at the first click after filling on the lowest setting always works for me.
also, I have found that EOCing or neutral coasting threw mine way off too. the neutral coasting tank that I did said that I should have gotten 43MPG for the tank and I actually got 36ish. that really threw me off and the neutral coasting was a lot of work for not a lot of reward for me. that may also be the case.
this is a weird one.
Old 09-18-2008, 12:09 PM   #6
I added 1 to the speed value because my tires are a tiny bit bigger, somewhere I found a signature link that led me to a tire size calculator that gave me the value. I'm running stock height tires, but a 205 width instead of 185, so it was just a tiny bit taller.
I don't always fill at the same station or same pump, but I always fill on slow and stop when it clicks off. My manual MPG calculations are always accurate (or at least, a lot more accurate than the SGII)
The most annoying thing is I only fill up every 2 weeks or so, so it takes me like a month to try and dial it in.
John
'01 KTM Duke 2
Old 09-18-2008, 12:46 PM   #7
I was thinking that 3+ gallons of difference was a lot of difference between stations.
I would think that either EOCing or neutral coasting to be a better culpret, do you do either of those?
Old 09-18-2008, 04:37 PM   #8
But according to his post he is using more fuel that the scan gauge is reporting if it were because of EOCing it should be showing that he's burning less than he's actually put in.
As far as neutral coasting it may actually use more gas than if he used DFCO. I tried neutral coasting in my '88 Escort for a while and saw a drop in FE.
Sounds like maybe you need to call Linear-Logic and see if they have any idea about what is going on. After my first tank in my '97 Escort mine has always been within 1/2 mile per gallon. Maybe there is something wrong with the calibration in your unit.
Hipermiler
#47 on my way to #1
Old 09-18-2008, 06:36 PM   #9
There isn't anything in the manuals about the CUTOFF setting, but from reading on SG's website they say it should be set at the idle TPS reading +4. Set one of your gauges to read TPS. Let the vehicle idle without touching the throttle. It isn't always zero for all vehicles. If your idle TPS = 1 then set cutoff to 5, if your idle tps is 5, set it to 9, etc. Hypermiling will throw the SG off. EOC, neutral gliding, and DFCO can all throw it off. The best way to calibrate your speed reading is to compare the speed reading to a GPS, and set the variance that way.
Old 09-19-2008, 04:46 AM   #10
My saturn has no DFCO, TPS in idle is zero, and I probably only do neutral coasting an average of 6 to 8 miles per tank of 300 miles. Not enough to throw this thing off that far.
I'm just going to monitor it again and see where it ends up here in a few weeks.
John
'01 KTM Duke 2
Electric lawn mowers bowtieguy Electric and Solar powered 38 04-07-2017 05:23 AM
pigfragger from NOCAL pigfragger Introduce Yourself - New member Welcome 3 02-28-2008 08:18 PM
Noooooooooooooooooooo!!!! unstable bob General Fuel Topics 8 08-17-2007 02:38 PM
worthwhile putting a 2.0 into a 3500 lb '85 Monte Carlo? MetroMPG General Fuel Topics 18 07-25-2007 03:01 PM
My last 3 fills popimp General Fuel Topics 4 07-15-2007 07:05 PM
