Sluggish VX at 40mph - Fuelly Forums
Old 05-20-2008, 02:45 PM   #1
slogfilet's Avatar
I've noticed this twice... when accelerating in my VX at about 40-45 mph in 5th gear, I get no response to additional throttle. I can floor it, but go no faster... I let my foot off the gas and coast down a bit, then try again and it's fine. This is on flat road, adn I can normally accelerate in 5th as low as 30mph. Any ideas?
slogfilet is offline   Reply With Quote
Old 05-20-2008, 03:32 PM   #2
EH3
EH3's Avatar
check the base mechanical timing
do a general tune up if you haven't recently
EH3 is offline   Reply With Quote
Old 05-20-2008, 03:39 PM   #3
jadziasman's Avatar
Downshift to 3rd gear and step on the gas. Woo hoo!
Old 05-20-2008, 04:08 PM   #4
haha. yes!
Seriously though, I was getting some weird hesitation in my VX from, as my mechanic put it, a dirty throttle bottle. He cleaned it and no more random hesitations. Not sure if this fits your scenario exactly but figured I'd throw it out there.
GasSavers_mango is offline   Reply With Quote
Old 05-20-2008, 09:06 PM   #5
mkiVX's Avatar
had that problem before
clean tps sensor or replace it
VX MASTER
SHWINN MOUNTAIN BIKE
GAS SAVER FAT BURNER
TOTAL MILES DISPLACED BY SHWIIN ON THE WAY TO WORK. 45 TOTAL MILES
mkiVX is offline   Reply With Quote
Old 05-20-2008, 10:11 PM   #6
suspendedhatch's Avatar
Throttle BODY. That was pretty funny. Valid point though. Your Honda throttle body should be cleaned once a year. Most people NEVER clean it. Make sure you buy the gasket BEFOREHAND cuz they can be hard to find sometimes.
Whether that's your only problem though I can't say. I think it's more likely your air filter or if your exhaust pipe has a restriction, possibly a clogged cat. Don't throw parts at it though. Have it diagnosed.
Old 05-21-2008, 04:03 AM   #7
Can't it be cleaned without removing it? By spraying some carb cleaner inside? Once you removed it, isn't that how you'd be cleaning it, anyway?
Also, the shop manual (page 11-124) describes a procedure for checking it with a vacuum gauge. If it passes this test, does that indicate it doesn't need to be cleaned? And what if your car is running fine (e.g. no hesitation, and no signs of the throttle sticking). Is it a good idea to clean it anyway?
Sorry for all the questions! I just appreciate a chance to learn something new.
Old 05-21-2008, 11:55 AM   #8
How embarrassing!
I did intend to write body but it seems that my fingers betrayed me somewhere along the way.
Old 05-21-2008, 01:20 PM   #9
A plugged cat would give you low vacuum readings at low throttle percentages with no load.
regards
gary
Old 05-21-2008, 10:09 PM   #10
civic lover's Avatar
I am not sure how you drive. If you drive with hypermiling in mind and never see above 3000 rpm it might not hurt to really whined the motor out a few times. These honda d series motors were made to scream. I drive very conservative, but sometimes pound on it. Cleans the motor out.
civic lover is offline   Reply With Quote
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 07:47 PM
