Tranny oil change using the return line - Page 4 - Fuelly Forums
Old 02-08-2011, 03:23 PM   #31
Re: Tranny oil change using the return line
or drain the torque converter thru the inspection plate refilling is tricky though
stickyburr is offline   Reply With Quote
Old 02-08-2011, 03:25 PM   #32
oh and SYNTHETIC! more temp stable = doesnt over thin hot and doesnt turn thick when cold .. just guessing pumping thick oil is way more labor intensive than motor oil which costs MPGs
Old 02-08-2011, 03:44 PM   #33
Depends on the vehicle. Many torque converters can only be completely drained by a complicated procedure that can only be done once, as it involves drilling a hole in the converter, and filling the hole with a rivet.
Old 02-21-2011, 06:25 PM   #34
add|ct's Avatar
Well, guys. I had to have the Stratus put into the shop to fix a botched timing service job, and while they were in there I had them just do another pan drop/filter change. I had the mechanic use Valvoline ATF+4, 4 Quarts, and I also put in a bottle of Lubegard Red to bring it up to the correct level. I have heard good things about this product and I'm giving it a shot to see if it will help my with the symptoms I was experiencing. Also, since the Stratus isn't my DD anymore, I will be sure to change the fluid every 2-3 years instead of waiting on the mileage.
'92 Civic VX, Canadian model
Old 03-02-2011, 09:50 PM   #35
You all should read this:
http://www.amsoil.com/techservicesbu...upplements.pdf
The bottom line...additives aren't necessarily good.
Where's the Jeep Wrangler forum? Revolution Fuelly Web Support and Community News 2 04-16-2012 09:40 AM
New HHO Setup nsgrossman Experiments, Modifications and DIY 4 02-08-2008 12:57 AM
