What is the FE sweet spot for... - Fuelly Forums
Old 10-04-2007, 03:47 PM   #1
does anyone know the FE sweet spot(hwy) for GM 3.8 v6(fwd) cars? my 95 olds apparently is not scan gauge compatible. will be testing my wife's car(same motor) for this soon, but since she drives very little hwy and her car is rwd, there prolly is no info benefit in it(at least for my car).
keep in mind that i'm NOT willing to drive 55mph on the 70mph FL turnpike. just want to know if 75 is more efficient than 70 or if 65 is MUCH more efficient than 70,etc.
any help would be appreciated! rh77 and anyone else that has owned/owns or rented one of these vehicles thanks in advance for your info.
Old 10-04-2007, 04:04 PM   #2
I used to rent Park Aves a lot around that time for work up north. I'd go 60 - 75 mph and get get around 28 MPG US. No idea where the sweet spot was, but it's an impressive powertrain for economy.
Old 10-04-2007, 04:24 PM   #3
omgwtfbyobbq's Avatar
Test it. Find a gas station and two a few round trip runs on the highway w/o traffic and the cruise set on 65/70/75.
Old 10-04-2007, 05:44 PM   #4
It really depends on the drag coefficient. The best FE seems to have been just above TC lockup. These cars like low RPM cruise. From the 3.1 in the Century or Beretta to the 3.8 in the Park Ave, Grand Prix, and LaCrosse, the best FE came from an average cruise speed around 50.
A good compromise might be 60 mph, but you'd have to test it out. Depends on the car...
Old 10-04-2007, 06:00 PM   #5
|V3|2D
thisisntjared's Avatar
the best way to know would be with a scan gauge, unfortunately i think that the sweet spot on an american v6 is pretty low on the rpm range i know they probably throw that top gear out pretty far so i think that rh77 has a pretty close estimate.
the slower the better. and i bet you will get significantly better fuel economy going 65 instead of 75.
i understand you want someone who speaks from experience, but my advice to you is don't go to slow, try to keep it at the speed recommendation(limit) of 70
Old 10-05-2007, 12:14 PM   #6
thank you all.
50mph does sound about right according to rpm(well below 2k). interesting tho, 70mph is ABOVE 2k(maybe 2200) w/cruise control, while without, it is right at 2k.
Old 10-05-2007, 12:37 PM   #7
TC
TC lock and unlock is pretty touchy on GM 4-speeds -- can you tell if the TC is locked at 70 with the CC on? That may be the issue. TomO mentioned this fix in another post -- firms-up the shift and helps prevent damage.
Old 10-05-2007, 12:51 PM   #8
very good link! i can feel my shifts, but not sure how to tell if TC is locked or not. how can i know? BTW, using amsoil AT fluid, so temp problems are not likely.
Old 10-05-2007, 12:53 PM   #9
You can tell by comparing the tach to speedo ratio...
Old 12-30-2007, 04:51 PM   #10
Bowtieguy,
As a rule of thumb, most engines achieve their best fuel economy at an RPM corresponding to a piston speed of 5 to 6 m/s (16.4 to 19.8 ft/s). Piston speed (ft/s)= 2*stroke(inches)*rpm/720.
Piston speed = 2 x Stroke in inches x rpm / 720
For the 3.8 GM V6 this is between 1740 to 2100 RPM.
Cheers , Pete.
GasSavers_Pete is offline   Reply With Quote
google+ integration? xchrislee Fuelly Web Support and Community News 3 07-15-2011 01:55 AM
GasSavers.org Stickers Matt Timion Fuelly Web Support and Community News 7 10-12-2006 03:48 PM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
the perfect civic MetroMPG General Discussion (Off-Topic) 5 05-20-2006 06:07 AM
Where to get parts? What parts do we need? Matt Timion Electric and Solar powered 11 09-19-2005 08:37 PM
