1979 VW Dasher Diesel - w00t! - Page 2 - Fuelly Forums
Old 04-12-2009, 04:17 PM   #11
Member
dletm08's Avatar
cool, a Dasher! they are rare. Are there any websites devoted to these cars? I can't find much online about them.
My Dad bought one in 1994. It was a Diesel, black 2 door hatchback. By 1996 it had valve issues and ended up parking it. Never got it back on the road and was scraped a couple years ago. Between it getting vandalized and the weather getting to it, it was too far gone.
Take good care of that thing!
dletm08 is offline   Reply With Quote
Old 04-12-2009, 06:00 PM   #12
Jetta90GL's Avatar
http://www.vwdiesel.net/ is an extremely useful forum for learning how to work with VW diesels.
Jetta90GL is offline   Reply With Quote
Old 04-13-2009, 10:54 AM   #13
Dalez0r is offline   Reply With Quote
Old 04-15-2009, 08:58 PM   #14
The seller was having difficulty resealing the injector pump (Didn't want to mess up the timing removing it), and has knocked $50 off the price in exchange for me dealing with it. He says it's losing about 1 drop per second, and it's not from a high pressure line. It hasn't seemed to affect the operation of the car. I can either fix it when I get there, or drive it with the leak. Assuming it doesn't suddenly get worse...
1 drop of water = 1/20ml (Size difference of a diesel drop vs water?)
1 drop per second = .05 gallons per hour. Not THAT big a deal...
I could measure it running the engine 15 minutes catching it in a cup I guess...
Old 04-16-2009, 06:06 PM   #15
Jetta90GL's Avatar
You could have him try the ATF seal reconditioning trick for a temporary fix. You basically run the engine on straight ATF fluid, and let the injector pump soak over night full of ATF. That should last long enough for you to drive it home.
Check this thread out over at vwdiesel.net:
http://vwdiesel.net/phpBB/viewtopic....eseal&start=15
Server Time ynpmoose Fuelly Web Support and Community News 2 12-20-2013 11:53 AM
2008 smart fortwo test drive Mike T Car Reviews 31 04-23-2008 06:12 PM
Amazed by the SGII GeekGuyAndy General Discussion (Off-Topic) 7 08-18-2007 11:25 PM
PepsiCo Connections? SVOboy General Discussion (Off-Topic) 3 10-12-2006 04:52 PM
VX rims... Update with pictures GasSavers_Jack General Fuel Topics 15 06-21-2006 07:29 AM
