Chip contest - Fuelly Forums
Old 01-06-2008, 12:35 PM   #1
Chip contest
I've been fascinated with installing a chip in my Powerstroke, particularly since my mileage has been so bad this winter. The last time I went that route, I installed a Granatelli Mileage Miser. The truck ran like a P.O.S., and the mileage got WORSE. I took it out.
Still, the Hypertech ads are too enticing to stop at Granatelli. They claim 2-6 mpg improvement. I'm going to try a Hypertech chip as soon as I can trot down to the dealer. The Blue Beast has a decent set of mileage data, so the results ought to be obvious. I plan to average the first 5 tankfuls, so the test will take over a month. I'll let you know when the test tanks start.
I'll send a $25 check to the guy that guesses the MPG improvement most closely, compared to the current gaslog, 17.96 mpg. Negative gueses are allowed.
Old 01-06-2008, 08:00 PM   #2
Commercially available chips might help a little if you have a really egregious fuel hogs, but idoubt it will help much.
Commercially available chips do advance injection and that helps efficiency but generally their fueling ""ramps" are so steep as to make it impossible to keep EGT down.
Everyone I've tried resulted in WORSE MPG. Today I run a one-of-a-kind custom-burned special MPG chip and it only gained me 0.75 MPG.
2000 Ford F-350 Super Cab Pickup
4x2, 6 speed manual
Regeared to 3.08:1
4 inch suspension slam
Aero mods: "Fastback" fairing and rugged air dam and side skirts
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Big Dave is offline   Reply With Quote
Old 01-06-2008, 09:21 PM   #3
DRW
What's the weather like in your part of the country?
Dave W.
Old 01-07-2008, 04:42 AM   #4
GasSavers_SD26's Avatar
My MPG did get better. Ran it on the lowest setting, Super Chips Micro Tuner, and that added 100 ft/lbs of torque. Great for getting moving from a stop and to maintain momentum on the interstate with small throttle openings.
The trick is that they become more fun to drive, and that sometimes causes one to use the throttle a bit more often...
Dave
Old 01-09-2008, 01:16 PM   #5
It's the Boston, MA area. We got a lot of snow and cold last month. Better now in January.
Old 01-09-2008, 02:40 PM   #6
lovemysan's Avatar
I guess I'll draw first blood. 19.5mpg
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 01-09-2008, 04:15 PM   #7
101mpg's Avatar
I'm guessing 18.4 mpg.
Old 01-09-2008, 04:48 PM   #8
GasSavers_Red's Avatar
20.2 Mpg
Old 01-09-2008, 05:38 PM   #9
GasSavers_Erik's Avatar
How else could a chip help a diesel engine except tweaking the injection timing? Or maybe advancing automatic transmission shift points?
Since diesels run ultra lean (unless you floor it), it seems like they ought to be pretty hard to improve on for mpg (without changing mechanical parts).
Old 01-09-2008, 06:42 PM   #10
lovemysan's Avatar
It could better control the torque convertor. Our PSD doesn't shift out of first until 2k rpms.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Creating a Switch to Shut Off Cylinders on the Fly SVOboy General Fuel Topics 78 10-08-2009 06:13 AM
Fuel cut-off threshold speeds GasSavers_Rotareneg General Maintenance and Repair 10 08-13-2007 05:27 AM
Search for members zpiloto Fuelly Web Support and Community News 2 11-30-2006 04:01 PM
Hello, from Gary Gary Palmer Introduce Yourself - New member Welcome 17 06-02-2006 04:42 PM
How I made my ****ty auto torque converter lock up without an auto ecu SVOboy Transmissions and Running Gear 17 03-29-2006 06:54 PM
